How do I replace side window weatherstrip - small rear seat window. Do I pull off chrome strip off window to replace rubber or do I just slide rubber out
Thanks Eric |
Assuming you are referring to the vertical weatherstrip on the front of the quarter window, it just pulls down. It was held into the chromed molding with a bit of weatherstrip glue.
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
My originals are rotted and tough to compare to new piece. There is a tab that sticks out bottom when slide rubber in window.
Where does this attach to |
the bottom "hook" in the rubber just sort of sits there, since repro's aren't as rigid there you might want to glue them
Thanks for help
Regular blue Dawn dish soap helps the new rubber slide easier as you push, pull and coax the new seals into position. Lube up the new seals generously with the dish soap.
Tim john--- |
The Following User Says Thank You to Tim john For This Useful Post: | ||
