We had a dyno session on my 535 2 days ago. I am happy with it...
https://youtu.be/yytXDevlzxw Sent from my iPad using Tapatalk
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads Last edited by 69Goat1; 03-31-2023 at 08:48 PM. |
The Following 5 Users Say Thank You to 69Goat1 For This Useful Post: | ||
Just watched the video. Nicely done and thanks for posting. Best of luck with the new engine. Love the 69 too!
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
Thank you!
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
Love it man, Thats some serius HP good job.
GT |
Q16 is our favorite fuel .It makes power ,Has a wide tuning window and is very consistent on the track.That being said The carb must be built Q16 Specific!.Main jet well etc must be sized for Q16.Many have run Q16 in Non Q16 built carbs and not seen the best results .WE have never not seen a gain from Q16 over C14-C15 _C16 -C25.Only fuel better is C45 .Which is very sensitive to tune.NA application .
Checkered Flag Machine & Ceralli Competition Engines Racing engines and induction development http://www.checkeredflagmachine.net/ |
Wow awesome dude. How is the blower engine coming along?
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4. |
I nixed that idea and just gonna put the blower back on my street car. I don’t have the crew or car to use the blower in a race application so cruise nights and burnout contest it is on a stock block 462...
So Johnny,
Is this a different version of the 535 I saw you race at Great Bend, a couple of years ago? Or another? I hope you (and I, long story on my end), can make it to Great Bend, this fall!!! Thanks, Jeff
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
The Following User Says Thank You to 77 TRASHCAN For This Useful Post: | ||
It’s a bit different. Just a few tweaks... I hope to see you at Great Bend my friend!
Nice numbers! Good luck with it!
My Half AN Injun..... |
Thanks for the info. Good luck with it. See you in Norwalk.
71 Lemans Sport. 72 Lemans Sport. |
The Following User Says Thank You to gman005 For This Useful Post: | ||
Awesome job!!!
The Following User Says Thank You to Scott Stoneburg For This Useful Post: | ||
great video, i have no idea the amount of effort it really takes to do those types of things but it looks like you have the editing skill and the right equipment. well done.
what are cam specs if you dont mind and how much did you gain from the last time you dynoed it? any details on the 1250 carb are you using?
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
What is the compression and what fuel ?
![]() Quote:
Gain from last dyno is about 27 hp. The cam is a Comp Cam, 50 mm, 4/7 swap, 281/292 @ .050 on a 112 with .485/.471 lobe lift. The 1250 I bought off a guy with a 1270 HP naturally aspirated 555 BBC. It’s jetted 100 square...
The Following 2 Users Say Thank You to 69Goat1 For This Useful Post: | ||
So the Q-16 fuel was worth + 43 HP at 5500 rpm, is that right?
We never dynoed it with anything but Q16. We put 112 in it to warm it up and that was 2 gallons worth. Our pulls were 5500, 6000, 6500, & 7000 twice.
The Following User Says Thank You to 69Goat1 For This Useful Post: | ||
Very cool video. 924 @ 6800 will make your day !
All that hard work came together. I see you have that Steffs pan. Looks great. BTW, your PMs are full. |
