which is top on thermostat
ooops, forgot this one. Does the spring go up or down on the thermostat in the manifold??? Its a 160 deg stant. Other question is should I gut the termost.; never had any real temp issues, just the typical in heavy traffic over 100 degs, sure it heats up. thanks. Ill also check some old posts.
66 GTO/PPR "ACE" BUILT 455/T-400/GROCERY GETTER DRIVER/WORK IN PROGRESS |
spring down, the cone on top.
463 Stroker Kit. ross pistons. h beam rods. eagle crank. 62 heads 72cc, port matched Performer RPM-850DP Auburn- 3.55 gear CC HR custom grind |
I though so,,, thank you. After reading some posts about temps,,, I may gut the thermostat.
I usually drill a small hole in the base of it to help bleed out the air anytime i have to drain the coolant
70 GTO 462 E-Heads TKO-600 9-Inch/3.60's |
The Milodon is a pretty nice, high flow unit. I like the high-flow types and I usually stick in a pan of boiling water so I can confirm that it works.
GTOlou, where can I get one of those thermostats?
Summit
Good post on thermostat types
See "johnsma22" post #6 re Balanced Sleeve (the Milodon mentioned below) and the standard Reverse Poppet thermostat. Good pic (which I saved) showing what each one looks like:
http://forums.maxperformanceinc.com/...d.php?t=430851 Seee-ya, Jim.
* '69 Custom S - 2dr Hardtop Coupe - Rust-free Oregon survivor with all original panels and original trunk floor * Engine alive and kickin' March 2nd, '06 * RA-IV 'spec' 400 (.060-over = 410ci), balanced, Comp Cams #9794041, #16 heads (72cc converted to large valve) with 1.65 Harland Sharp Rollers * QuadraJet #7042210, HEI, Hurst V-Gate, FlowTech Headers, X-Pipe with dumps, Flowmasters, TH-350, 3.90 Posi * Best ET: 14.06 - Bandimere Speedway, CO. @ 5,800+' |
