Good news from the machine shop today
Finally got the call I was waiting for from the machine shop where I dropped off my engine. He said everything looks excellent! All of the oil galleries are clean. The crank is in great shape and doesn't need to be turned. So I ordered my new bearings today all standard size. Also all of the cylinders measure at 0.001" taper. My deck height is currently at 0.020 and he will deck it to 0.005. Also all of the pistons look like new. All he has left to do is deck the block, polish the crank and brake the glaze on the cylinders.He said he's going to try to have it all finished by the end of next week. The only thing I need to get yet is a new dipstick tube. I'm going to order the stainless steel one from our host.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
Happy happy happy.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
Yes! Lol he had called and asked if I could stop by the shop; I was expecting the worst. But I was looking at all the old bearings while he was dealing with a customer and everything looked great.
How much is a polish of the crank?
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
Not to sound, well,crazy but just how can he tell if oil galleys are clean unless he removed the front & rea plugs???
He did remove the front and rear plugs.
Spud, don't use Locktite on your rod bolts/nuts. If you have ARP bolts/nuts, then use ARP Ultra moly lube. If using stock bolts/nuts, use 30 weight motor oil. Torque them to specs, then go over them after they are all torqued down. None should turn anymore before reaching torque. If they do, they are stretching and need to be replaced. If the bolts/nuts come loose, it wasn't because you didn't use Locktite, but rather because they were not torqued down.
The Following User Says Thank You to gtofreek For This Useful Post: | ||
10-30 would probably be fine.
With all the work and labor my total is 300 so for just polishing the crank I'm not positive.
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘22 Toyota Sequoia V8 ‘23 Lexus LS500 awd ‘95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
My total cost was $300, of that I know $140 was for decking the block. So $160 covered cleaning the pistons and rods, taking all measurements, baking and cleaning the block, polishing the crank and installing new cam bearings and casting plugs.
I ordered a stainless steel dipstick tube from our host yesterday so I should have everything I need by the time my block is done. I will be doing reassembly and am wondering If I should use blue lock tight on the threads of the rod studs upon reassembly?
Machine Shop Bill like that means a 1-piece oilpan gasket from Butler's sounds affordable.
I thought about one but seeing as how I'm well over on an already tight budget I'm going to use the complete gasket set I already have. I do however need to get another set of valve cover gaskets since I'm adding a valve cover spacer.
make sure you run a good oil pump 60 psi.
Nice to hear good news on a tear down and a fairly simple reassembly.
The one piece gasket is really nice but with some patience the stock type stuff will work. I really like to use Permatex (Right Stuff) seals very nice. I personally dont use any thread locker inside a motor. If everything is clean and threads are straight then use a good calibrated Torque wrench and your good to go. |
Congrats! I love to hear a happy shop story!
"...ridge reamer and ring compressor? Do they have tools like that?" |
thanks! im looking forward to some official forward progress lol
I got the block back Friday. Saturday afternoon I received the new dipstick tube from our host. I wish it would've been a tighter fit than it was but with a little high temp rtv it went in snug. Double checked all of my oil clearances on rods and mains and all are 0.0015-0.002". The rotating assembly all went together smooth as did the windage tray, lower dipstick tube and oil pump. I'm still waiting on my cam and lifters which I'm not too happy about as its been just over 2 weeks now. So since I'm waiting now I went ahead and bagged the engine where paint should no go and primed and painted it and set the already painted parts on the block and everything looks great. So I guess I'll update again once my cam and lifters arrive
