Exhaust Gasket
What is the best exhaust gasket. Factory RAIII manifolds. Leaking withe old metal gaskets. What should I get?
Remflex or whatever RARE sells have worked for me.
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
2X Remflex.Tom
High temp silicone on the mating surfaces, let it skin over for 15-20 minutes, and assemble. Let it sit overnight before starting it. There are a ton of racers that only use RTV on their headers, and no gasket.
I've seen it repair turbochargers, so if it can stop a turbo from leaking it can surely fix naturally aspirated. I used it on a set of Hooker header gaskets installed in 1989, still not leaking 33 years later. |
The Following User Says Thank You to Sirrotica For This Useful Post: | ||
RemFlex is a VERY good gasket
1978 Trans Am Pump Gas 461 Stroker |
