67 gto console vs. lemans
Is the console the same in the 67 Lemans and the 67 GTO?
Will the Lemans console work with my Dual Gate shifter? |
You would have to butcher it to make it work. It might be better to sell that one and get a dual gate console.
They all look the same on eBay.
Except for the plate that attaches to the shifter they all look the same. |
No major issue to do this.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
The Following User Says Thank You to Jeff Hamlin For This Useful Post: | ||
The LeMans used a two speed auto trans and the console top had a different configuration than the GTO Hurst Dual Gate console. As stated above you could modify the Lemans console to work with the Dual Gate. Cannot go the other way however.
I have both LeMans and GTO consoles available for 67's if your in need. |
The Following User Says Thank You to GTO JOHN For This Useful Post: | ||
Visual reference...
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 03-08-2015 at 08:21 AM. |
Awesome
So, the console's listed with the big hole are the ones I am looking for. Thanks a ton for the help. Chris |
Correct but be sure it isn't someones attempt to do the same thing and possibly cut too large to be covered by the plate/escutcheon.
I appreciate all the help.
I am going to buy an inexpensive console and make the modification. I figure I can spend $200 on a console that is all there and needs paint and new wood grain application. This will get me close and later I can upgrade to something very nice. |
