Out with the old. In with the new (soon)
Looks like my 474 ate a bearing last Wednesday after racing. I was driving home when the dreaded knocking sound started. Pulled over quickly and got a trailer to get it the rest of the way home. When pulling it back into the shop there was no noise, but the oil filter had a lot of bearing flakes in it. Pulled the 474 out today and took the pan down, looked at 4 rod bearings and they are not the culprit. Some metal transfer, but the journals just need a polish. Its taken 7 years of street and strip abuse. Not as long as I would have liked it to last. I was planning on swapping the 535 in at the begining of the year anyway. I will be putting the 535 on the dyno hopefully in December then dropping it in the car.
Not a happy time, but atleast you did not ventilate the block!
Was/ is it a cast Crank in the motor from the aftermarket?
Yes, the block lived through it. Its a factory crank. I am thinking its probaby a main bearing. The knock was intermittent, didnt knock at all coming off the trailer or driving into the shop. Due to my work schedule I probably will be pulling more of it apart this coming Wednesday.
Sad that's for sure! Sounds you will still have some decent usable parts left.
For the next back up! |
I decided to get off my a$$ this morning and look at the bearings. Most were nice. 1 main had some copper showing but smooth, not all chewed up with flakes missing. # 6 rod had some material transfer but crank looks good. # 8 is the one that spun and was hammering. Rod has some "blueing" from heat. Crank looks ok. Still think maybe just a polish. Nothing i can feel with my fingernail. So, hopefully 1 new rod, polish the crank and reassemble. Still have to completely disassemble so the diagnosis could change.
Pic is # 8 rod cap bearing half |
What connecting rods were in the engine and did #8 seem to have full torque on the fasteners when you removed them?
Glad it wasn't any worse than it was Scott. The 535 will be fun!
What kind of main bearings were it it ? Slotted or the round hole.
