Need Info On 67 Engine compartment Plug/Box
Good morning friends, in my last question I needed help with the ignition switch. This time, my question is about a small box (please see photo) in the engine compartment. The small box is located next to the front light bulk head box, next to the engine harness block. It has two wires on the front side, and one in the rear that came from the old engine harness. I'm helping the older guy replace the harness in his 67 Le Mans. I wont mention some shop installed a 454 in the car, because the box if factory Pontiac. Any information will be a big help. Thank you again for all your help, and best wishes. PS: it's the third rear wire from engine harness I don't understand. Mike
Build it fast, build it right, hold On TIGHT !!! |
Horn relay. Be careful with it, original Little Fuse relay. If not good, I can rebuild it.
That is the horn relay. Plug the matching harness to it so you'll have working horns.
Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
Oh gee, thank you. I should have known that. For some reason I thought the relay was at the front of the engine compartment. Thanks friends. Mike
