OK this is not about a Pontiac Engine, but there are some things of interest here and some related to a Pontiac engine build. There is an article on this engine in the December issue of Hot Rod Magazine.
The GM crate engine makes 1,004HP and is designed to be a street engine. This is the same engine that is used in the 2024 COPO Camaro. It has 12.0:1 compression and is designed to work on 93 octane pump gas, huh? It's made at the GM Performance and Racing Center in Pontiac Michigan. It has a custom ground Comp Hydraulic Roller cam made to GM specs using Chevrolet Racing anti-pump-up Bowtie lifters secured in place with a “spider” hold down plate. Looking at the design of the spider plate I see no reason why one couldn’t be fabricated for a Pontiac, but it would be expensive and doubt there would be enough sales to make it a profitable venture. It would require some expensive tooling to make the stamped sheet metal portion. The dog-bone portion appears to be made from 3/16 plate or cast then braised or spot welded to the stamped sheet metal. The stamping acts as a spring to hold the dog-bones in place to prevent the lifters from rotating. The valve springs are ovate wire beehive to control the big 2.450 intake and 1.8 exhaust titanium valves with .780/.782 lift and 175 pounds on the seat and 410 pounds over the nose. The redline is 7,000 RPM and max power 1,004 @6,600. Another interesting aspect of this engine is the use of coatings on the piston top and all exterior of the piston. I suppose the coating on the top is to retain heat in the combustion chamber inside of the large 32.3cc dish and on the exterior to reduce friction and for durability. It uses Cometic .040 MLS head gaskets and the pistons are .005/.006 in the hole. I also found it interesting that it uses 15W 50 oil with bearing clearance of .027/.028 on the mains and .0023/.0028 on the rods.
Tim Corcoran |
The Following 3 Users Say Thank You to Tim Corcoran For This Useful Post: | ||
Did you miss a zero on the mains??? 27 thousandths seems a bit wide to this amateur.
The Following User Says Thank You to Bill Hanlon For This Useful Post: | ||
Yes I did miss a zero, sorry my mistake. Should be .0027/.0028
Tim Corcoran |
Pontiac Ram Air V - Chief Stomp ’Em
Bore sizes to increase to a whopping 4.500 inches. Combined with the Bryant billet crankshaft stroke of 4.785 inches, displacement works out to 609 ci. https://www.motortrend.com/how-to/60...hief-stomp-em/ Dyno pull: https://www.youtube.com/watch?v=Q0z9j08khy4 .
Thanks for this review!
Well this could certainly be done with a Pontiac, and yes it would take very deep pockets. We do have a block that will make that amount of cid. That amount of valve lift for a street motor gives me white knuckles so I would prefer a solid roller over a hydro roller. I think that to get the level of air flow needed to make over 1000 Hp at only 7000 rpm that one would need valves that size like they used. With the bore spacing of our motors I think running a Hemi type head to get those needed valve sizes would be the only way to go. I think that with any motor built like this and run on the street the main issue will be valve spring longevity. I would be surprised if some of them did not start to go south by the time you racked up 4000 miles .
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 10-20-2023 at 03:59 PM. |
![]() Quote:
Spring tech has come a long-long way.
GT |
![]() Wasn't there a run of tall deck height Pontiac Blocks? Does anyone remember what their deck height was? Stan
That would be a awesome engine to have. It’s probably $30,000.00
6,600 rpm to make 1,000 HP NA is darn good.
The Following User Says Thank You to i82much For This Useful Post: | ||
![]() Quote:
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
The Following User Says Thank You to AG For This Useful Post: | ||
The type of hydraulic lifters in that block could not be used in a Pontiac block...a FWIW
That BBC has a 2.40" valve. I am sure that head has a ridiculous amount of flow we could never have.
4.75 stroke with a 4.60 bore. Must be nice, still a freaking Chevy. |
![]() Quote:
Stan
Troy,
Not sure what that is from but not the ZZ632. Just look at post #1 or below. Stan ZZ632/1000 DELUXE TECH SPECS Part Number: 19432060 Engine Type: Chevy Tall-Deck Big-Block V-8 Displacement (cu. in.): 632 cu. in. Bore x Stroke (in.): 4.600 x 4.750 in. Block: Cast Iron Bowtie with 4-bolt main caps-tall deck Crankshaft: Forged 4340 steel Connecting Rods: Forged steel H-beam 6.660" Pistons: Forged aluminum 2618 alloy Intake Manifold: Aluminum high-rise single-plane Throttle Body: 4500-style Fuel Injectors: 86-lb/hr Camshaft Type: Billet Steel Hydraulic Roller Valve Lift (in.): 0.780 intake/0.782 exhaust Camshaft Duration (@0.050 in.): 270º intake/287º exhaust Cylinder Heads: Aluminum spread-port; 70cc chambers -RS-X design Valve Size (in.): 2.450 intake/1.800 exhaust,Titanium (5/16-in stem OD) Ignition Type: 58X crank-triggered, coil-near-plug Compression Ratio: 12.0:1 (nominal) Rocker Arms: Forged aluminum; roller-style Rocker Arm Ratio: 1.8:1 (shaft-mount) Water Pump: Aluminum Oil Pan: Steel 8-quart Recommended Fuel: Premium pump (93 octane or higher) Maximum Recommended RPM: 7,000 Balanced: Internal
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
![]() Quote:
https://www.shafiroff.com/chevy-pump...isted-sr20.php |
Stevie…. Dream on if you think any Pontiac motor configuration can make 1050 hp on pump gas.
For $23,000.00 never gonna happen |
Besides the article in the current Hot Rod magazine, there are also several previous stories about the ZZ632 available on the Motor Trend website that go into detail on how it's built and how the heads were designed. https://www.motortrend.com/s/zz632/
Thread Tools | |
Display Modes | |
