1970 WS 400 stock rebuild
I plan to use the Mellings CL-SPC-7 cam and lifter set on this stock rebuild. I want to use the stock rocker arms and push rods but don't know the correct ratio for the rockers or length of the pushrods. Is there a resource here to find this info? Thx.
1970 T/A |
The rocker ratio would be 1.5 and the push rod lenght stock was 9.130 to 1.935" or so.
Note that the ideal lenght for the push rod due to geometry changes from milling the heads or block may need to change. Also a valve job being done can change the length of the push Rods needed.
I do stuff for reasons. Last edited by 25stevem; 11-16-2022 at 12:40 PM. |
Sometimes I have to reread my posts 3 times when I am in a hurry with the info. Tom V.
Just do not use stock rods. Not worth the risk and run a forged piston while you are at it. No hyper BS.
The Following User Says Thank You to Dragncar For This Useful Post: | ||
Thanks for the advice and input gentlemen. Dave
1970 T/A |
The great side benefit from running lighter aftermarket rods, pistons and wrist pins is a engine that revs faster,
This in itself add’s nicely to acceleration performance.
I do stuff for reasons. |
for a stock rebuild... stock rods are perfectly fine. & even stock type cast pistons are fine for a stock build or even a slight 50-100hp increase.
if the OP intends on higher performance or light duty racing or frequent higher rpm use then its a good idea to consider better rods/pistons/other parts, but he said stock rebuild, no need for forged rods & pistons. countless people run stock rods even on higher hp builds for decades, i had a 455 that was abused & saw 6000 rpms daily for 10+ years, plus the 20+ years of life the rods were used before me. |
The Following User Says Thank You to 78w72 For This Useful Post: | ||
It is too valuable to run cast junk rods. I would not run them in any engine I cared about and put a bunch of time and money into. Cast rods are about 50 years old without any real info on cycles or RPM they have been to unless you have been the original owner and the only one to drive the car. I had a friend that blew 2 cast rods out of the oil pan because he was cheap. Glad he is out of Pontiacs these days. Only so many left. |
Just remember, New doesn't mean good. While I agree the Chinese rods are made of far superior material than the OE rods, and are forged. The machining processes need to be checked for size on each and every rod, big and small ends. Although Eagle stuff is much improved, we are still seeing some that are on the very edge of the tolerance range and even outside by .0001"-.0002". This means some are over .001", larger than the minimum. Have a set of Eagle press pin rods for a Chevy in class. 4 out of 8 had .0005-.0006" press fit. That just isn't enough, even on a .927 " pin. Had to put oversize pins in that set. Not a big deal but please check everything and expect some new parts will need work before installing. Just checked a "balanced rotating assembly" for another Chevy Tuesday. It was out 6 grams on the front and 16 grams on the rear. It would have worked OK like that but it certainly wasn't "precision balanced". No reason to expect Pontiac stuff to be any better.
i have owned quite a few stock rod pontiac engines like the 455 i mentioned that was beat & abused daily, saw 6000+ rpms countless times before i knew better for 10 years... stock rod bolts too since i was a broke kid doing a cheap rebuild. currently have a W72 400 that didnt have a budget for $500 forged rods nor did i feel they were needed for a 325-350hp street car, but its been drag raced & ran pretty hard on the street for about 12 years now. i trust the rods for that type of use & trust my engine builder that prepped them. all i mentioned was that when prepared right stock rods are are fine for a stock engine or even a mild build that is kept within a reasonable rpm. with the OPs cam i doubt he has plans for 6000rpm WOT runs at the drag strip or beating the crap out of the car on the street. he was asking about rockers & push rods, then gets you need forged rods or else the stock ones will break... surprised nobody has told him he needs a huge cam & shave/deck the heads/block for 9.5:1 or it will be a turd. nothing wrong with using forged rods if/when they are needed, i just dont feel they are needed for a completely stock build but the OP is free to do what he wants. as mentioned above even new rods still need fully checked over & sometimes work done to make them right, prepping & resizing my rods didnt cost anywhere near $500. |
Some folks don’t seem to understand that to be 100% safe even at only 5000 rpm when running stock factory cast iron rods you need to know there history.
Important things like how long they have been run for ( as in cycles) and how high they where ever taken up to rpm wise and even if a motor may have ever seen a overheating condition and if the rods ever had to deal with full throttle fuel knock all make a difference. These days with the cost of buying and installing new rod bolts and then re-sizing factory rods of unknown history ( like If you have not owned the motor since day one) playing with fire and is also so close to the price of new rods ( under 500 bucks) that making a case for using them is bordering on nonsensically.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
I'm going to show my age here and say that before forged rods were available, it was common practice to prepare stock rods by shot- blasting to stress relieve them and then polishing the beams, Both operations improved stock rod longevity. Today, you also have the option of using superior ARP rod bolts. That said, at today's prices, this preparation would likely exceed the cost of new, forged rods.
Triple Black 1971 GTO |
Jeff |
Shot blasting (peening) is a way to increase fatigue life of the rod. The process leaves a layer of compressive stress on the surface. Compressive stress is what usually happens on the inner diameter of a bend so it's a weird thing to picture as a result of shot blasting but it's there.
Fatigue cracks start on surfaces and need tensile stress to initiate and grow. So the idea with shot blasting is to add a "negative" or counter-acting stress to the tensile bending stress that happens when the engine is running. The shot blasting basically increases the stress needed to start a fatigue crack. It would be a good thing to do to any rod. |
Years back I pounded stock shortblocks hard high compression and NOS all I can say is never broke a stock rod not saying it doesn’t happen but it’s not going to automatically happen because you make 400hp. Personally if I had a stock set of rods I knew came out of a stock original engine I would have no problem using them in a stockish rebuild. My2¢
The 69-70 RA IV had regular rods, right? I recall CARS magazine impressed how it was still smooth at 6500 rpm.
You can find story after story of guys doing amazing things with stock rods.
Still, I would not use cast rods in a 70 4 bolt 400 block. And if I had a actual RAIV engine that needed a rebuild it would get some Crower rods. |
Smooth when up at 6500 was due to the accuracy of the factory balance job, surly you must understand it had nothing whatsoever to do with cast rods used in the motor.
And just the getting to 6500 cleanly was also in part due to the RA4 motors use of valve springs with a open pressure of 320 PSI . Back then only solid lifter motors from Chrysler with there Hemi and two Chevys BB motors with solid lifters had more spring pressure.
The problem with building a mild 400 is lack of a good cast piston. Run as far and fast away from HT's as you can, and NEVER use the stock 8 valve relief variety as they sit WAY too low in the holes at TDC providing too much quench and squish area.
Stock rods are OK for mild builds and will probably last forever if you don't hang a HEAVY low-end forged piston on them. I wouldn't be afraid of them with a set of light weight modern forgings pressed in place. Years before we had good affordable forged rods we ran cast rods in 455 builds in full race applications spinning them to and past 6000rpm's w/o any issues. Good thing there is a decent amount of sheet metal between the engine and driver with those builds as I've never been very comforable spinning cast rods that hard in any of these engines. Stock stamped steel rocker arms are fine for most of these builds and a better choice than many of the aftermarket roller varieties. They are strong, light and fine if you aren't running 450 pounds of spring pressure and .600" or more lift. About the only roller rockers I'd even look at are Crane Gold Race, Harland Sharp or Crower Enduro. I've burned up, cracked or broken just about everything else that's being offered for these engines, plus they can be a PITA to get under stock valve covers without some work.........
The Following User Says Thank You to Cliff R For This Useful Post: | ||
Thread Tools | |
Display Modes | |
