Old 04-06-2024, 08:37 PM
sglemans sglemans is offline
Default Gas gauge stuck on F after getting gas
71 T37
I only put $20 gas in, gauge was on 1/4 left before. Comes out to about 5 gallons, and when I went to drive off the gauge was on Full. Don't know what happened. Strange thing is, even after I pulled the battery it's still on F, so I guess it's not electric related?
Just out of curiosity, If it's completely full tank, would it stay on F all the time, even with no electric? Or do I have a bad gauge?
Old 04-06-2024, 09:03 PM
OG68 OG68 is online now
GM gas gauges would often remain at the 'key on' setting or drift a little bit after the ignition is turned off.
I always thought that was strange, coming from a Ford ownership background where the gauge always went to empty when the ignition was off.
2007 Cadillac SRX
Old 04-06-2024, 09:04 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Check you sender ground 1`st. Black wire that bolts to the car underside somewhere.
Total ground = empty.
NO ground = full, to past full.
The Following 3 Users Say Thank You to PunchT37 For This Useful Post:
Old 04-06-2024, 10:25 PM
Would it be a ground issue though if the battery is disconnected?
Old 04-06-2024, 11:29 PM
PunchT37's Avatar
Yeah. You will have no grounds with the battery disconnected.
Old 04-07-2024, 12:15 AM
So basically if there was no electric it would be pegged on Full, and grounding it would make it go towards empty in varying degrees?
Old 04-07-2024, 12:39 AM
PunchT37's Avatar
No. It won`t move with no power. The sender varies the ground with power applied to the gage. You can ground the tan wire on top of the sender. With the key on, the gage should go to empty.
Old 04-07-2024, 12:01 PM
Is that ram wire in the trunk with a plastic connector?
Meant tan wire
Old 04-07-2024, 02:32 PM
PunchT37's Avatar
Yep. Ground the side that goes back to the front, with key on. Watch gage. Should go to E. If not, the troubleshooting begins.
If it does, then most likely, the sender is bad or the black wire, that I talked about earlier, has a bad or dirty connection to car chassis, or tan wire has problem between trunk connector and sender.
Old 04-07-2024, 07:46 PM
I'm taking a wild guess on this, but since it happened right after I got gas maybe it's a stuck float? If it was, would it correct itself at some point by changing the gas level ?
Old 04-07-2024, 07:57 PM
PunchT37's Avatar
Anything`s possible in an animated cartoon.
Old 04-08-2024, 01:40 AM
wakesupremo wakesupremo is offline
Sorry for hijacking this but i have a related problem. My gauge reads ok unless i have lights on. Then it reads constantly full.
Old 04-08-2024, 07:02 PM
PunchT37's Avatar
Grounding problem. Check for body to engine ground, dash ground behind the cluster, etc.
