Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Never Raced McCarty/BES/INDY Cartel RamAir 5 Top End for Sale.
10K
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
Includes Head Studs
Bump
What size is combustion chambers & what do they flow?
Carburetor building & modification services Servicing the Pontiac community over 25 years |
CC Volume is ~80CC
Who's flow bench is that on? It's illegible on the attachment. Thanks Ed
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
BES Racing Engines Flow Bench.
Includes BES Ported Intake with EFI bungs.
Xmas Bump
News Years Bump.
Easter bump
RA-V 356T-6 Alum
O-Ring Heads Dry Deck Heads BES Racing CNC RA-V Head Porting BES Racing CNC Combustion Chamber BES RAcing Alternate Intake Valve Spacing Valve Guides PPP Special "Tool Steel" guides Valve Spring Cups Manley 42371-16 10 Degree Titanium Retainers Manley 23640-16 VALVE SPRINGS Manley 221425P-16 Valve Locks Manley 13162-8 Lash Caps Nitrosteel Victory VLC-341125 Intake Valves Victory Stainless Severe Performance 2.300 diameter Exhaust Valves Victory Super Alloy Inconel 1.750 diameter Intake Valve Seats Special T hard seats Exhaust Valve Seats Special T hard seats Single Plane Dominator Intake Manifold w/Injector Bungs BES Racing Intake Porting ARP Head Studs T&D 1.65 Stainless Shaft Rockers w/Spring Oilers and Needle Bearing Tips Smith Brothers Push Rods for T&D Shaft Rockers Other parts also available.
Do you know if the deck is thick enough to surface the O rings out and can the deck be wet?Tom
Hey Tom,
The aluminum plugs can be drilled out to convert them back to wet deck. The o-ring is a .041 stainless wire, the heads would most likely need to be milled .030 to .032 to remove the grooves. I can measure them at a few spots, but realistically Jim Robertson may be the best person to answer this question.
Tom, I reached out to Jim yesterday. He will check the deck thickness on the set he has and weigh in.
You may not need to get rid of o-ring grooves if gasket bore is small enough to cover them and not interfere with bore.
From my notes back in 2010/2011...deck thickness is .600" on Tom S's heads. Best of luck on the sale.
Jim www.raceV8s.com 1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th. |
Thank you Jim!
Tom S, .032" off the deck of the heads (with a measured .600" thick deck) is a non-issue as far as a "skim cut" on the heads. CCs in the combustion chamber would change by about 4-5 ccs so the compression ratio would go up some though, as you know.
Might actually help on a non boosted engine with improved compression ratio. Tom V.
