Old 01-14-2024, 10:57 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default Reducing Bounce - second wheelie - When Coming Down from Wheelstand
Hey Guys - request help with Reducing Bounce - second wheelie - When Coming Down from Wheelstand with 72 GTO.
https://youtu.be/-wb5zU-Rdh8
Car launches straight, carries the wheels.
New best with a 6.41 at 105.5 and later spun at 106.
Still launching at 3,500 - 2-step with 5,000 still to grab.
Turbo 400 4.11 Pro gears with MT 10.5w x 28 slicks
Front suspension:
Strange Engineering Rebound adjustable front drag shocks
Adjusted to 90/10 settings
Landrum 5 x 18 #180 springs and sits close to lower control arm bumps
Low friction control arm bushings and ball joints
Total Race Weight 3440
Front weight 1860
Rear weight 1580
Percentage Basis Front to rear 55% to 45%
Rear suspension:
Full length Competition engineering adjustable ladder bars
Bottom hole lowest front heim end setting
Right bar - slight preload
“5 x 13 #150 lbs - springs with spring jacks
Comp Engineering double adjustable Rears Bump at 6 tight and rebound at 3 tight
Pinion angle 2 degrees negative
MT 10.5w x 28 slicks with tubes at 14 pds cold - best runs
Thanks Guys, Craig
Old 01-15-2024, 01:24 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Talking strictly about reducing bounce, wouldn't shocks closer to 50/50 be needed?
Old 01-15-2024, 06:21 AM
mysticmissle's Avatar
Agree you have our grown you’r shocks look into Viking or strange double adjustable and then you can stiffen the compression so
It won’t bounce and unload the car once it lands
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 01-15-2024, 12:04 PM
CraigG.'s Avatar
The strange single front I have Have a set bump of a 90/10 - so will the strange doubles be stiffer?
Old 01-15-2024, 12:24 PM
John Langer's Avatar
John Langer John Langer is offline
Afco off the shelf bnc valving shocks will fix the problem. Me personally, I would stay away from the qa-1/strange single adjustable. The valving in those are too inconsistent.
Old 01-15-2024, 12:25 PM
Old 01-15-2024, 12:39 PM
CraigG.'s Avatar
Does the rear seem to hit the tire too hard?
Old 01-16-2024, 04:56 AM
gman005's Avatar
gman005 gman005 is offline
I run Viking. They helped out a lot with that.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 01-16-2024, 02:14 PM
grandville455's Avatar
Slow the rebound a click or two in back, tighten the comp on the front if u can, if u cant, get some good DA shocks and don't look back, I agree
with john some afco bnc would work!
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 01-16-2024, 02:15 PM
Darby
Old 01-17-2024, 05:58 PM
ErikW's Avatar
ErikW ErikW is offline
AFCO BNC shocks for sure and you need to address your bump steer also. Global west makes a nice steering arm that virtually eliminates it. https://www.summitracing.com/parts/gls-ss-6472gskb
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 01-17-2024, 09:37 PM
CraigG.'s Avatar
Actually - I changed the steering arms with the global west arms.
Old 01-17-2024, 10:58 PM
aaronman aaronman is offline
X3 AFCO BNC shocks. Most all the Super Stock racers and bigger wheelstanding bracket cars I have seen run them.
Old 01-20-2024, 10:56 AM
firechickenman's Avatar
firechickenman firechickenman is offline
I've been really pleased with my Viking Crusader hybrid coilover setup. I worked with Mike Proulx at Viking to pick out spring rate and shock valving. I was skeptical of the 350 lb springs he recommended, but he nailed it! Previously, I had Moroso trick springs and Calvert 90/10's. Street manners are much better. No bouncing and the car settles down to normal ride height about 200 ft down the track. Also, they are about 19 lbs lighter (11.5 lbs compared to 30.5) than the Moroso/Calvert setup.
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 02-12-2024, 01:41 AM
Probird's Avatar
Probird Probird is offline
I tried the Afco BNC shocks and they were very stiff on the compression. Made the car bounce worse than the shocks I had on it. Get the Afco double adjustable shocks.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
