fel pro manifold gasket
Fel-Pro ms 90123...........had them on my car before, so i bought them again........seems the only way they will work is to flip one of them over..........when i pulled them off, didnt pay much attention at the time............does this seem about right for you guys that used these..................both are the same, stamped 90123 R 5
Thanks for any info Rich |
Yes pay no attention to the felpro marking on one install them like it makes sense don’t overthink it
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
Sam
-- Sam Agnew Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it. Ministry - Jesus Built My Hotrod |
Rich |
The Following User Says Thank You to gtorich For This Useful Post: | ||
Don't try to glue them. Use the grommets to hold them in place. Not a real need for the wax either (although it will not hurt anything) the blue coating is Teflon.
Rich |
Oh...
Maybe a couple of dabs of RTV on each gasket. Let it dry, obviously...
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '69 LeMans Vert, 350, #47 heads: work in progress |
Thank you guys, im slapping those puppies on tomorrow..........then i can get back to my oil pan not fitting issues.
Rich |
I like Pam or equivalent cooking spray lightly coating gaskets if you think you’re going to be removing it often
Rich |
The Following 2 Users Say Thank You to gtorich For This Useful Post: | ||
Should they always be put on dry?
------------------------------------------------------------ 1967 Bonneville Sport Coupe (Plum Mist), Org. paint, Org. 38K miles 1967 Bonneville Convertible (Montego Cream, Cal Car, 105K miles 1967 Executive Wagon (Plum Mist), Org. paint, Org 35K miles 1981 Bonneville Brougham Coupe (Black) Moonroof, Org. 11K miles |
I like to put a little sealer just around the water crossover holes... probably not needed though.
Greg Reid Palmetto, Georgia |
This is where Gasgacinch shines. Apply to both the head and gasket surfaces and wait to tack up, then set the gasket in place. Get it right the first time since the two surfaces will stick immediately. The good thing about Gasgacinch is the gasket will peal back off leaving a slight residue in a few areas that can be easily rubbed off with the fingers. Sort of a rubber cement for automotive use.
I always use Ultra Grey around the coolant holes and that pretty well dooms the gasket for reuse. If I don't trust the ability of the manifold surfaces to totally seal, I'll cheat and apply a very light coat of Ultra Grey around the edge of the ports to fill in any possible gaps. Kind of penny wise and pound foolish in worrying about saving the gasket for reuse.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon. |
