Old 05-26-2024, 08:33 AM
dv657172 dv657172 is offline
Default Header wrap/motor mount question
Looking to replace my stock reproduction motor mounts on a 65 GTO with a 68 400. Launch car off of a transbrake at about 4,000 - 4,500 rpm. Currently a 12.0x car but chipping away at it.
Butler recommends the following set but states "if using headers a heat shield or header wrap to keep heat away from the Poly mounts as excessive heat may cause the poly to melt or deteriorate".
Butler Performance Pontiac Polyurethane/Stainless Steel Interlocking Engine Mount, 64-72 GTO, Set BPI-2255-6P
https://butlerperformance.com/i-2445...tegory:1393554
Any one using these and what did you use to combat any heat issues?
DV
Old 05-26-2024, 12:29 PM
Dragncar Dragncar is offline
Never had any heat issue with mounts. Everything I have ever heard about header wrap is to stay away from it. Unless you like rusted headers.
Old 05-26-2024, 01:06 PM
65madgoat's Avatar
I melted the driver side one on the chassis dyno with Doug's headers. Added a metal heat shield around these motor mounts and no issues since....
Old 05-29-2024, 09:03 AM
Thanks guys for your thoughts!
