SCE copper head gasket
I pulled my cylinder head off to re-lap a intake valve in, when putting head back on I noticed that the head gasket had stretched. Wouldn’t go on the pins without bowing gasket.......what’s up with that?
GTO George |
My SCE gaskets did all kinds of stretching in its short life...I am basically having to completely rebuild my brand new engine now and will never use a copper gasket again no matter what.
GTO George |
I had a issue with a set of custom SCE copper gaskets.Made to use as a hybrid with reg pontiac heads on a 301 block.The fire ring was like 51 thou thick and the gasket was like 42.NFW that firering would compress enough to seal the gasket.$650 for the dyno,250 for the gaskets,no idea of the breakin oil etc,we ended up with a flood in the dyno room,water in the oil etc.Complete tear down.Sucked.Last time I use them.Tom
I already ordered another set, next year I’m looking into a fire ring set up!
GTO George |
GTO George |
You said next year you’re looking into a fire ring set up, I said these guys can set you up. I’m not sure what the ? Is about
GTO George |
I used Hussey's copper gaskets and didn't have any stretching or bowing of the gasket, .055" thick gaskets with steel wire O rings, just 18 psi of boost though, up to 220f coolant temps at one point.
Yours are probably getting hotter than you think ,or unevenly heated/cooled. |
George do you monitor exh temps?
One on each side.
GTO George |
We had a few minor issues with a set of Clark Copper. I have never used SCE. The Flattout rubber coated copper were great and stayed in shape and sealed very well for us.
