WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 1993-02 Firebird/Trans Am Owners > 93-02 Suspension Tech
93-02 Suspension Tech springs, sway bars, trailing arms, lowering kits, etc.
Old 11-15-2014, 11:59 AM
SteveGB21's Avatar
SteveGB21 SteveGB21 is offline
Send a message via Yahoo to SteveGB21
Default Tech tip on the 93-02 (& 82-92) F-Body lower control arms.
I found out today that if you buy the inserts for the '64-'72 GM A-Body Lower Rear Control Arms, that they also will fit the '82-'02 F-Body. That is what I will do instead of buying a set of control arms. If anything helps with saving money (only got the polyurethane bushings) then that will work for me. Car is a V6, and I don't plan on using it as a drag race car or trying to maneuver as fast as I can. Just a daily driver.
Now, if I only can obtain an insert for the panhard bar.
Featured Vendors
Advertising Info
