2.25 header flanges?
Who has 2.25 headers flanges? All i can find is 2 1/8
Me too. Mr die grinder meet mr 2 1/8 flanges. Continue until a feeling of satisfaction is generated....
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
Lol, looks like i'll be doing the same
I can give you a .dxf file with 2.25" port openings so you can get laser/water cut. I drew up flanges for my motor as I needed 1.875" ports but couldn't find them locally so had to resort to computer wizardry to have made locally
With a port opening that big I need to move the the inner ports outwards slightly as to not overlap and not clip the bolt holes. This is how my set I made turned out.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
i make 2 1/8" ones, the biggest problem is the spacing between the center bolt holes.. you could oval those holes up and down to get the 2 1/4" tubes into after opening and not loose bolt clearance. or what i do is a 2 1/8" stepped to 2 1/4" tube... depending on what you are doing that may be a better option..
kal www.xtremefabrication.com |
