Old 05-06-2019, 09:53 PM
newmexguy newmexguy is offline
Default 1965 Post Door
'64 - '65 Post driver's door. Loaded with internals, wing, and side glass. $259 plus shipping will remove glass and ship that seperately. Dave S dona Ana NM 88032
ID:	511718   Click image for larger version
ID:	511719   Click image for larger version
Old 05-08-2019, 08:49 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Is the aluminum trim around the outside of the door/window in good condition?
Old 05-08-2019, 09:12 AM
Default 64-65 Pontiac A post door Hollander #1726
Can take some closer look / pictures but to be honest am trying to sell this whole for a local yard. It is not mine. The car it came from is long gone - likely was crushed in the early/mid eighties.
Old 05-08-2019, 05:25 PM
400 4spd.'s Avatar
Looks like a '66 door to me.
Old 05-09-2019, 11:35 AM
The upper door hinge is aluminum. Never parted much first gen A stuff, thought aluminum door hinges ended in 65. Hollander shows 64 - 65 interchanging then 66 - 67. For door hinges. Post trim all there, but has yard damage. This door may have been loose in yard for thirty five years. Just saying but it is solid on bottom pinch weld. Hinge areas and latch areas good. No inner panel speaker cut outs.
Old 05-09-2019, 04:17 PM
400 4spd.'s Avatar
The reason I suspect it's a '66 door is because in '67 they started using a stamped steel upper hinge, not cast like the one you have. Another minor difference is with the door bumpers 66 to 67.
The reason I know it's not a '64 or '65 door is because of the outer skin. Note the contour of a '65 door.
I'm not trying to nit-pick your ad, just thought it would be helpful to point out the year differences.
Old 05-09-2019, 05:23 PM
Okay, thanks, am a generalist, with a GM focus, mostly Chevrolet, not a Pontiac expert. Most of the parts I have sold over the years have been Chevrolet. And most of them have been '68 and up. I was going by the Hollander manual, for the door hinge application. For identification purposes, here.
The Following User Says Thank You to newmexguy For This Useful Post:
Old 09-29-2019, 12:19 PM
Default 66 Post door, Drivers' side
This drivers door assembly still available. Thanks. Dave S dona ana NM 88032
Greyhound shipping available.
Old 11-10-2019, 12:32 PM
to the top.
Old 11-20-2019, 11:49 AM
To the top. Apparently then, there were "carry over" hinges used in '66 according to some of the members here. Thank you for the clarifications. Still here, will remove glass and wing window for shipping purposes. Thank you Dave S dona Ana New Mexico
Old 12-16-2019, 08:12 AM
Still available, to the top.
Old 02-26-2020, 09:46 AM
66 Post Door, Drivers' for sale.
Old 04-05-2020, 05:00 PM
To the top.
