Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
Shower curtain
Ok this may sound like a silly question BUT
I just installed a 3 piece fiberglass tub stall/surround.... I dont want glass doors had em before and pain in the ass imho.... Anyway....I want to install a curved shower rod...can I drill into the fiberglass surround and use wall plugs or somethin to secure the mounting plates for the curtain rod???? Any ideas from those who have encountered this I appreciate the help.....Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
I just redid my bathroom. Using a 6' shower curtain and the same curved rod, mine is too tall to mount into the surround. I mounted it into the drywall above the surround with metal screw in anchors.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
no go mine is a complete surround top to bottom...
put a hanger bracket on the wall adjacent to the enclosure.
tuck shower curtain in on the bottom and it can be outside the enclosure at top. You can use a bracket like a curtain rod hanger.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
I also went above my shower stall with my curved rod. The length of your shower curtain is going to partially dictate where the rod goes, I wanted mine inside the basin but not laying on the bottom.
Mitch Kunath |
What's behind where you would be drilling? Seeing you have access with the trim off you should be able to mount to though the shower stall to a solid piece. Here are some images.https://www.google.com/search?q=curv...w=1920&bih=862
'68 GTO '69 Corvette '75 Cadillac Coupe Deville TOM |
