Old 08-11-2005, 09:58 PM
GTOLou GTOLou is offline
Default high torque mini starters
I searched old threads - only brands I really saw mentioned were the IMI, Powermaster and ?hitachi?
Anyway - any one have current advice on best mini to use. 400 w/ only ramair manifolds. MOST interested on ease of installation without inticate adjustments, etc.
Thanks, Lou
Old 08-11-2005, 11:48 PM
60man's Avatar
60man 60man is offline
I actually bought one off of ebay two + years ago. The manufacturer was Hi-Test Racing/aka Hi-Test Rebuilders out of California. They had a good price but stater was only rated at 1.4 kv. Most I have seen are at least 1.9kv rated. My last motor was a 12-1 compression deal.Unit came with shims,mounting bolts, and a gauge for measurering drive to ring gear gap. I wound up using no shims but removed a shim between the mounting block and motor to get gear closer to flex plate. There was a foul up on shipping and I recieved two starters !! Rather than having me return the extra starter they made me a deal I couldn't refuse. I just recently lost a tooth off drive gear. I think a under charged battery was the culpret. I called about getting it repaired. No problem,just send it back and it will require two days turn around time. I think I paid like $110.00 for one and then $79.00 for the extra. I judge a product not only by quality but service too. I'm pleased on both counts. There are lots to choose from now and prices are competitive. This is just my experience.
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 08-11-2005, 11:59 PM
vidguy's Avatar
vidguy vidguy is offline
I bought a starter from those folks as well in 2004. He was very helpful. The workmanship looked excellent. I am not running the unit any longer as I reverted to a stock setup again. But I would recommend him for the same reasons.
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
