Old 12-31-2023, 11:13 PM
Tinindianworkshop's Avatar
Tinindianworkshop Tinindianworkshop is offline
Default Nunzi cam
Just saw one on fb anyone know specs nunzi 2041 ???? 068 but higher lift thanks Geoff
Old 01-01-2024, 12:02 AM
Stan Weiss's Avatar
I don't know what the part number is for this Nunzi cam. Looking at the date on the file, I got the lobe information in Aug of 2015 and don't remember from who.
Stan
Pontiac Pump Gas List
Old 01-01-2024, 11:00 AM
Tandyman Tandyman is offline
Ron's Pontiac page lists it
https://ronspontiacpage.com/reference-pages/nunzi.htm
Glenn
Old 01-01-2024, 11:07 AM
Cliff R's Avatar
Cliff R Cliff R is offline
http://www.pontiacpower.org/PontiacCams.htm
Old 03-18-2024, 09:43 PM
PontiacPadre PontiacPadre is offline
Default Nunzi 2041 in a 455?
Cliff R, I just acquired a 1974 455 that I eventually want to drop into my 74 Ventura. I haven't rebuilt the 455 yet. The car is primarily a cruiser. I will use the 1974 #46 heads from the 350 with screw in studs (will send them off to get 2.11 intakes) and I have a Nunzi 2041 laying around I was planning to use in this motor. The Ventura has a 3.08 posi rear and a 1977 Q-jet from a Trans Am. Will the 455 be undercammed with the Nunzi 2041? What do you think of this combination?
Old 03-18-2024, 09:47 PM
Old 03-18-2024, 09:55 PM
Tim Corcoran's Avatar
Tim Corcoran Tim Corcoran is online now
For a cruiser with a stock converter it would be a great cam, 1.65 rockers would give you a little more performance. With a good 2-1/2 inch exhaust with free flowing mufflers it would be very nice with a little lump at idle.
Tim Corcoran
Old 03-19-2024, 05:41 AM
Why would you think it would be under cammed when the 73-74 SD455 came with a smaller Cam then that?
