Old 01-27-2014, 05:22 PM
ELKHORNAOG7 ELKHORNAOG7 is offline
Question Which is right and which is left ??????
I know I should not be using this thread but I need to know one thing about a (hyundai) an 2005 2.7 engine I need an 02 sensor on bank #2 and the parts store sell them for right bank and left bank asked 2 dealers how do you know right from left standing behind the engine or in front of the engine and got 2 different answers now I still don't know which dealer is right, does some one out there know for sure where I would stand for right and left,---thanks,---BOB
Old 01-27-2014, 05:46 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
[quote=ELKHORNAOG7;5119288]I know I should not be using this thread but I need to know one thing about a (hyundai) an 2005 2.7 engine I need an 02 sensor on bank #2 and the parts store sell them for right bank and left bank asked 2 dealers how do you know right from left standing behind the engine or in front of the engine and got 2 different answers now I still don't know which dealer is right, does some one out there know for sure where I would stand for right and left,---thanks,---BOB[/quote]
It's not where you stand but where you sit. The right side is the passenger side. The left side is the drivers side. Unless of course you are in England and then it's a bit more confusing
Karl
Old 01-27-2014, 06:04 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
lIs it a side winder v-6. Looks like radiator side.
http://en.allexperts.com/q/Hyundai-R...nta-fe-GLS.htm
Sensor 1 before cat, sensor 2 behind cat.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 01-27-2014, 06:14 PM
BB70's Avatar
BB70 BB70 is offline
To identify bank 1 you have to identify cylinder #1. Whatever cylinder is #1, that O2 on that side of the engine is bank 1. O2 1/1 would be the upstream 02 on bank 1.
Sometimes identifing cylinder #1 involves some legwork also.
Treed by Blued-
John
Old 01-27-2014, 07:38 PM
Well I know # 1 cyl. is back at the fire wall but the parts store sells the part by right bank and left bank since it is front wheel drive me being behind the steering wheel still won't tell me which is right or left so how do I know which is right or left. Looking at the engine from the trans. side or looking at the engine from the front (the belt side)----BOB
Old 01-28-2014, 01:19 AM
BB70's Avatar
Picture the engine as if it was a rear wheel drive setup. Passenger side is the right side.
Old 01-28-2014, 01:45 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Look at the engine from the trans side, radiator side is left and firewall is right. Bank 1 would be the bank with #1 cylinder so bank 2 would be left or rad side.
64 Lemans hardtop
4spd, buckets
Old 01-28-2014, 02:05 AM
sts sts is offline
To identify the left-right side of ANY engine: Stand in front of it, transmission/flywheel to the back. The right bank is to your right and the left bank is to your left. All left-right engine identification has been done like that since the invention of an engine. And to this day, it’s still SAE sop.
The #1 cylinder on a Pontiac V8 is located on the left side of the car, but it’s still on the right bank of the engine. Does this help explain why the automotive industry has its own defaults to reference parts?
Old 01-28-2014, 06:50 AM
1972 Pontiac Service Manual, page 6-47,
"The cylinder block...has two banks of four cylinders each, cast 90° to each other. Left bank cylinders are numbered 1-3-5-7 from front to back and right bank cylinders are numbered 2-4-6-8."
I guess Pontiac didn't get the memo?
Karl
Old 01-28-2014, 07:47 AM
pontiac1981's Avatar
pontiac1981 pontiac1981 is offline
I would say rad side is the left bank. if you turned that sideways engine around and facing forward like it's suppose to be. LOL!
Old 01-28-2014, 01:29 PM
Talking
Gentleman not to start a PISSING contest BUT someone here is right and someone is wrong I still don't have the answer to right or left PONTIAC1981, 72 LUXURY, LEMANS 64, & BB70 say it's from the rear of the engine and STS says it is from the front of the engine same type of answers from the mechanics from the two different dealers I sure wish the parts store would have said bank #1 or bank #2 I guess they are looking for the answer also. I don't want to put out $153.00 and have the wrong side. I would think that the 2 downstream sensors would be the same as would the 2 upstream sensors be the same.---BUT---I'm just not sure. Thanks,---BOB
Old 01-28-2014, 01:43 PM
Chris65LeMans's Avatar
I'd bet that a call to your Hyundai dealer's service dept. would solve this.
Old 01-28-2014, 09:23 PM
Talking
This is where I got the answer from 2 different hyundai dealerships. ( LOL )---BOB
Old 01-28-2014, 10:18 PM
BB70's Avatar
Bob, pull the old one out, part# should be on the old one. If there's not, measure the length of the wiring lead & look how the connector is layed out, that's usually the difference between upstream-downstream, L&R 02 sensors
John
Old 01-29-2014, 10:51 AM
Schurkey Schurkey is offline
Got the SAE standard number to back this up?
Old 01-30-2014, 01:52 AM
Bank 1 contains cylinder 1
Left and right are as viewed from the drivers seat. Left and right of the engine are as viewed from behind the flywheel.
Bank one on the side winder below is the firewall side. Band 2 is the radiator side.
Let it be written, let it be done.
The Following User Says Thank You to Blued and Painted For This Useful Post:
Old 01-30-2014, 02:49 AM
gtofreek's Avatar
gtofreek gtofreek is offline
Typically, if you are talking about front wheel drive cars, you need to find the front of the engine. Not front as in front of car, but rather front of engine as far as pulley's, timing cover etc. That is usually the passenger side of most FWD cars. Once you identify the front of the engine, stand behind it and then you will have the right side on your right and the left on the left.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 01-30-2014, 01:15 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Iv`e never seen O2 sensors sold as right and left. Iv`e been in the auto repair business for 25 yrs. Bank 1 will be ANY sensor that "sees" cyl. 1. All 1`s are before the cat and 2`s after. Some v6`s & v8`s have only 3 sensors not 4. So, one would have bank 1 sensor 1, bank 2 sensor 1, and bank 1 sensor 2. The after sensor sees both sides BUT, it sees cyl. 1 so, it`s a bank 1 sensor. Lots of `95 and older vehicles are this way.
The sensor 2 sensors will not affect engine running. They are for the cat efficiency codes.
Old 01-30-2014, 01:21 PM
PunchT37's Avatar
Get a diagram of the exhaust system and see where that sensor is. Parts places should have these. Order that sensor.
Old 02-01-2014, 12:07 AM
Talking
Well I checked with another dealer and they said that the engine is right or left by standing in the front of the engine and not from the transmission side------BOB
