Mega brace by SD performance
Is this something that you can buy used and would it be worth it? Or just buy a new set. Thanks Bill
Pretty sure it is best to custom fit(grind) to a specific block's valley.
SD is advertised as no grinding. ?????
You always grind them some if you are smart.
Bill - can't say that I've seen any braces for sale used but I'd pick one up if I came across it. New or used it may still reqire some fitting.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
From Dave's website: "no grinding required to clear any bolts." That's different than grinding the lifter bore cups on the brace to fit properly. I also had to fill in recesses in the fitted area with JB weld. It might take a pretty big hammer to get them out, and they probably wouldn't be in that great of shape to sell at this point.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon. |
Thanks guys! That's answers it. I just buy new and grind brace to fit.
I will be putting 2 used ones that are in PERFECT shape on my Garage Sale section monday!! http://www.pacificperformanceracing....dage-tray.html
Ace
Am I glad I got out of the business I was in? HELL YEAH!!! |
Thanks Ken I'll check after work Monday
Thanks Ace!!!!!!!!!!!!! For all the help.
How did you get in touch with him? I called Friday about the second set,but never heard back.
My mistake. I only had 1. Sorry Gary. He asked 1st.
Ace
No problem. I knew he was first. I would have been interested in the second set.
I don't believe there was a second set. I suspect the count reflected the number of pieces (not including hardware/retainers). It's two pieces, unless you want to do the entire valley - it's "four" then. HTH.
