Can someone knowledgeable with 1965-1966 Carter carbs help identifying a carb with the following stamps ?
Cast # on carb body is '1565' Cast # on carb top (bowl) is '1694' Thanks, Dave dlarkins@comcast.net
'65 GTO Hardtop ![]() 389 .030 400ci Tri Power, .068 cam, HO manifolds, M-20 4 SPD, '70 12 Bolt 3:36 Chevrolet posi-traction, Montero Red, Parchment gut, VINTAGE AIR, PFDB, Bilsteins, F&R HD Sways, Hotchkis rear bags, Firestone Indy 500 shoes "What's the point of owning a muscle car if you can't scare yourself stupid from time to time ?" |
Cast #1565 (stamped #1737 underneith, next to throttle bore) and cast #1694 was used for 1965 Pontiac Carter AFB´s.
You´ll need to find the stamped #´s on the venturi clusters, primary and secondary, throttle side and choke side, to be 100% sure what application. |
Thanks Kenth !
