RobbMC Fuel Pump Users Question
For use with an IA2 block, any mods required to the 1100HP pump to fit correctly?
I asked Robb via email and he said he wasn’t sure with the All Pontiac block. MR1 requires some light clearance to work. Thanks in advance. |
Not an actual user but cam and timing set and timing cover are all
In the same place w an ia2 as a stock block should Be fine only Difference is on oil pan rail and that should not effect pump Unless the added material around the bore, (to gain support) hits the body of the pump? I guess that would be possible but I’d go to an electric pump Before I ground my block if it was me
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
The Following User Says Thank You to mysticmissle For This Useful Post: | ||
Thread Tools | |
Display Modes | |
