SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
Pontiac 535 Race Engine
Pontiac 535 - 945hp Race Engine
Dyno time only. Short block is new. Heads refreshed. All Pontiac Steel Block, 50mm Roller Cam Tunnel, .842 Bushed Lifter Bores Crower Billet Crank. 4.5" stroke, 3" main, 2.20" rods, Center Counterweights Callies 6.7" Ultra Rods Ross Race Pistons with Total Seal Gas Ported Low Tension Rings KRE 430cfm Hi Ports, 55cc chamber, New SS valves, PAC 1248 Springs and fresh valve job Port Matched BOP intake T&D Shaft Rockers 1.75 Ratio, Smith Bros 3/8" pushrods Crower Bushed Offset Intake Roller Lifters Comp Cams 50mm Roller 4/7 Swap Sims Roller Timing Chain Modified Melling Oil Pump Stefs Oil Pan, ATI Balancer, MSD Distributor & Crank Trigger, Moroso 4 Vane Vac Pump Custom Taylor Plug Wires/Looms Mezziere Water Pump Compression 14.75:1 All machining done by Jax Specialty Engines in Minneapolis. Engine comes with all build clearances, pics of assembly process and specs.References available. $25,000 No trades. Can deliver to Norwalk Pontiac Nationals. Message with any questions. Thank you! |
Sorry. I'm located in Somerset, Wi. Just outside the Twin Cities.
Good deal. One would have a hard time duplicating this engine for double the price.
Also not wait a year to get it done. |
Sold. Thank you PY.
Thread Tools | |
Display Modes | |
