I have just finished repairing my core support which on my 71 GTO involved replaceing the sheet metal where both mounting holes were. I know the distance between the 1" holes form the frame position. My question is, are they centered in the center of the channelof the core support, or moved some distance forward or back of the center of the channel.
Thanks, Randy |
Are you talking about the body mount holes? I looked at my '70 and they are centered.
On my 71 they look centered. Did you replace the whole lower channel or just weld in patches?
"Honestly the car will only be there for a few weeks, OK maybe a month at the most" |
Thanks guys,
After looking closley, I assumed they were centered and cut them that way and every thing seems to fit. Rusted, I patched the passengers side which had the holes rusted out to about the size of the bushings by cutting out the top brace about 2 1/2 X 3 inches and welding a piece of 16 guage in place. Turned it over and cut out the piece in the channel longer in order to not match up the welds. The drivers side was completely gone from the bushing hole over to the end of the core. I made about four different pieces to reconstruct it. i was surprised that it turned out as well as it did, and the inner fender lined up. All this took me longer than I expected as it was my first welding job |
Rusted,
Here are some pic of the repair. Before |
Patches
Still needs some finishing
![]() Quote:
I've got some pix of my '70 core support repairs (no comments about the crappy welds, it's my first welding job too): http://www.curryosity.com/family/all...restification/ Also, I have some '70 assembly manual scans here: http://www.curryosity.com/family/all.../front-end.asp Mine was nowhere near as bad as your, though - minor battery acid rot by comparison. I'm impressed by your efforts...
Bought: 1970 Le Mans Sport Convertible (second owner,) Palladium silver, 350/2bbl (sigh) with Comp Cams 268H grind (installed by previous owner), TH350 Trans. Mods: Front suspension: Global West negative roll tubular upper arms, Del-a-lum bushings, Koni shocks, 12" disc brake conversion, 1.1" front sway bar, Rear suspension: Global West tubular control arms, springs, sway bar. Exhaust: Flowmaster 2.5" American Thunder system. Mostly complete: Firewall-forward engine compartment restoration Last edited by DIYGuy; 11-01-2005 at 02:01 AM. |
Diy,
Nice ride. My 71 is a convert too. Good job on the repair. I am satisfied with how it ended up for a first shot. Saw the other day where some one makes "repairr" kits for Buick core supports. Pretty neat deal. Why not for Pontiacs? We know there is a market for them. Randy |
Thread Tools | |
Display Modes | |
