Old 07-02-2003, 07:57 AM
80TA 80TA is offline
I will likely get some roller rockers like crane gold ones..do they clear under the elite valve covers.I think edelbrock only make the one height one for pontiacs..?? And where do you get pontiac valve cover
wingnuts since the chevy ones don't fit..at least on stock pontiac heads..I assume the edelbrock heads might use chevy bolts for the wing nuts on the valve covers..??
80TA,pontiac 400,edelbrock carb,accel wires,dual exhaust,dynomax mufflers,no cats,3.42 gears.CE subframe connectors to be installed.On order B&M quicksilver,Polygraphite bodymounts,3000 converter.
14.94 at 95.2mph 2.45 60ft uncorrected tazzo vpc.
99TAWS6 ..lots of mods.13.35 at
109 2.27 60ft uncorrected tazzo vpc.
1900 ft altitude.
80TAWS6,400,edelbrock 750 carb/performer rpm intake/crane cam and lifters,/magnum 1.52 rocker arms/comp pushrods/arp rocker studs,cloyes double roller,crower valve springs,ias shocks,msdl wires,dual exhaust,flo pro mufflers mufflers,turbo 400, 2400 nitrous holeshot,3.42 strange gears.
1900 ft altitude.
Old 07-02-2003, 11:58 AM
SCOTT ESTERLE's Avatar
SCOTT ESTERLE SCOTT ESTERLE is offline
Moroso has the wing bolts & soreaders. Yes they should work unless your running a stud girdle. Edl heads use the same t-bars as stock heads do.
Old 07-02-2003, 12:13 PM
73ta's Avatar
73ta 73ta is offline
work just fine with 1/4" cork gaskets
Old 07-02-2003, 08:10 PM
Joel Koontz Joel Koontz is offline
I recently installed Eheads and Elite Valve Covers with H/S 1.65 rockers. The Elite Valve Covers are tall enough but I had an interference problem with 4 of the rockers hitting the indentation in the valve covers where topside bolt holes are. I ended up grinding the corners off of the rockers to get them to fit. The rockers and Elite Valve Covers worked fine on the 6X heads I was using before I got the Eheads so I think it is probably because the valves are slightly repositioned in the Eheads.
The Following User Says Thank You to Joel Koontz For This Useful Post:
Old 05-03-2024, 02:45 PM
theroot68@gmail.com theroot68@gmail.com is offline
They won't fit. Going through this now with roller set up, Edelbrock heads, and Comp. Golds. Purchased spacers. I know this is an older thread, but maybe it will help somebody.
Old 05-04-2024, 09:14 AM
Tim Corcoran's Avatar
Butler sell valve cover gaskets in different thicknesses they even have them in 5/16 thick.
https://butlerperformance.com/i-2445...tegory:1234816
Tim Corcoran
