Old 04-28-2024, 12:30 PM
LET LET is offline
Default Muncie M 20
I got the Muncie 4 speed On the bench. Took the cover off, looked pretty good .
Watched one of Paul's videos to make sure i put it back together right. I watched him spinning the trans by hand so i tried that so i could check for chipped teeth. I can't spin it, it will rock back and forth a tiny bit. Put in reverse and it spins EASY! Took it out of reverse, won't spin. I think i have it in second gear.
Any ideas?
Thanks,
LET
Old 04-28-2024, 03:08 PM
3 & 4 gear set in neutral?
Old 04-28-2024, 03:35 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
You probably have it in two gears.
Old 04-28-2024, 05:19 PM
LET LET is offline
Yes, I believe three and four are in neutral
