Old 03-02-2024, 09:53 PM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
Default performer rpm intake pcv valve
obviously, this intake does not have a pcv valve provision in the best place. Is it possible to drill and tap this manifold for a equal division like the original 72 intake? I may just have to put the cast iron intake on and be done with it. The trade off doesnt seem reasonable to be for the weight savings but maybe there is a trade off somewhere.
Old 03-02-2024, 11:31 PM
PAUL K's Avatar
PAUL K PAUL K is offline
We try to run the PCV to the carburetor baseplate and the brake to the vacuum port on the #7 cylinder or put a fitting in the plenum.
Go fast, see Elvis!
Old 03-03-2024, 04:14 AM
joes455 joes455 is offline
Let me know if u decide to sell the rpm
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 03-03-2024, 12:08 PM
400 Lemans's Avatar
Post #6 has a pic where a pcv fitting was added.https://forums.maxperformanceinc.com...d.php?t=661260
The Following User Says Thank You to 400 Lemans For This Useful Post:
