Industry Stuff new repro's, updates, other info.
Old 10-23-2019, 11:47 AM
OG68 OG68 is offline
Default The Horn Works
I had the horns from my 68 GTO recently restored by Gary Steinkellner of The Horn Works from Beloit Wisconsin. He rebuilt a set for my El Camino several years ago and they are still looking and working well. The craftsmanship is very good
If your are looking to restore that original set of horns I highly recommend him.
Gary Steinkellner
608-361-0095
www.carhornrestoration.com
ID:	522744   Click image for larger version
ID:	522745   Click image for larger version
2007 Cadillac SRX
The Following 3 Users Say Thank You to OG68 For This Useful Post:
Old 10-24-2019, 01:14 AM
android 211 android 211 is offline
I used him too and the horns work well for me as well.
Old 11-15-2019, 10:42 PM
jstites jstites is offline
how much to restore a pair?
Drive it !
69 Trans Am coupe
70 Trans Am
76 SE 455 hardtop
87 GTA
89 Turbo TA
02 CETA Convert
The Following User Says Thank You to jstites For This Useful Post:
Old 11-16-2019, 11:05 AM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
Go to his website for pricing details
https://www.carhornrestoration.com/proc1.html
Old 12-22-2020, 09:49 AM
Greg Reid Greg Reid is online now
He did a great job on those. I recently restored a set for myself. Easy and enjoyable project but I have no way to duplicate those heavy rivets so I used stainless nylon insert nuts and screws.. Have no idea how he did that.
Made a little test n tune rig for them...
Name:	68 horns.jpg
The Following 3 Users Say Thank You to Greg Reid For This Useful Post:
Old 02-20-2022, 03:53 PM
rwfisher's Avatar
rwfisher rwfisher is offline
Gary does excellent restoration work at a reasonable price and the turn around time is great.!!
Old 02-22-2022, 10:45 AM
bhill86's Avatar
bhill86 bhill86 is offline
I’d like to know more about what you did to get yours working again.
1977 Trans Am 400/4speed (swap)
Brian
Old 02-22-2022, 12:51 PM
Sorry, I didn't know that was directed at me.
They are actually pretty simple and usually the problem is crusty or rusty diaphragms.
As long as the coil has continuity, which you would check with an ohmmeter between the prong and the body you should be able to get it working like new. If you don't have a way to check that it's okay because it's very unlikely that that will be broken.
The way it works is this- There is a coil of wire surrounding a metal, movable core so it works like a relay.
When you press the button current flows through the coil moving the slug. The slug is attached to a thin metal diaphragm so that it gets an oil can action when the coil magnetizes and moves the slug. There are a set of points, one point contact is fixed and the other is attached to the movable diaphragm. When current flows it pops the oil can one way and as soon as it moves it breaks the contact so that it relaxes the diaphragm again but as soon as that happens current flows again and it pops back. This happens at a high enough frequency that it makes a buzz. The buzz is amplified by the horn body. That's it.
All you have to do is grind the rivets out and make sure everything inside is clean with no dirt, or rust so the diaphragm is flexible. Clean everything up including the contact points, replace or fabricate a gasket to seal the two halves together water/air tight and use screws in place of the rivets.
After doing that you can use a current meter, which is what is pictured in my post, rigged up to adjust the current for peak value while the horn is being energized. There is a screw with a jam nut on the horn that you do the adjustment with. If you don't have a current meter you could probably do it by ear. Just adjust it for the loudest clearest tone.
Mine are still working and looking great.
Old 02-22-2022, 01:44 PM
bhill86's Avatar
Hey thanks Greg. I got curious in the meantime and dug out my non working horns and took one apart. I didn’t see anything apparent but I quit for the time being so I could finish up some other stuff. You’re right though there’s not much to them.
Brian
Old 02-22-2022, 03:28 PM
Make sure that the contacts are clean and that you have continuity all the way through from the power prong to the body. Current has to flow all the way through to make the oil can 'pop'.
Old 02-22-2022, 04:44 PM
bhill86's Avatar
Thanks for the tip
Brian
Old 02-22-2022, 07:28 PM
dataway's Avatar
dataway dataway is offline
When searching for used horns is there anything special about the GTO/Lemans/Tempest horns? Was there a year spread? Did all the Pontiacs use the same horn? Etc.
Old 02-22-2022, 08:38 PM
I honestly don't know dataway. I know there are different frequencies available but l don't know which ones are which. I seem to recall some identifying markings on them..but...crs is acting up again. I have some photos somewhere l believe but may have lost them on my old phone.
Old 02-22-2022, 09:02 PM
Scott Thelander's Avatar
68-69 GTO horns are # 9000 251 9000 252
I have a couple spare LOUD pairs they are date coded also for the fin ick ee
1 pair mixed dates
and also several sets of builders if needed ,,,,
Scott
Old 02-22-2022, 09:42 PM
Scott, I think l recall getting my cores from you after foolishly throwing a pair away that l'd gotten from the salvage yard. I threw them away right before l found out about rebuilding them.
Old 04-11-2022, 11:22 AM
roger1's Avatar
roger1 roger1 is offline
Once again Greg I see that you have a level of patience that I just don't seem to have.
You showed it with how you dealt with the bending of the grille trim and now with dealing with horns that don't work.
After finding out a few days ago that the original horns on my GTO had issues, I took one apart. I bent it up some doing that as I had to pound so hard on the rivets to get them to come out after grinding off the heads. After removing it from the vice and seeing what I did, my patience pretty much ended right there and I decided to just buy the reproduction set from Ames.
My hat goes off to you sir!
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
Old 04-11-2022, 01:13 PM
Roger, you forget that I have seen your work and you sir, are a master... Considering that you don't do this for a living is amazing.
I could only dream of having the level of skill you have displayed!
Old 06-14-2022, 04:40 AM
Justinmac Justinmac is offline
Scott, I believe I obtained my cores from you after throwing away a pair I'd gotten at the scrap yard. I threw them away before I realized I could reconstruct themoctordle
Old 06-14-2022, 11:33 AM
dld's Avatar
dld dld is offline
he can also date code them
