Fresh rebuild now to fast
After 5 years I freshened up the 455. Went from .040 over to .060. Freshened up the heads also. Machinist ground the intake valve to 38 degrees with out me knowing he did it. I was worried about the change. He told me it would help low lift flow and if performance suffered he would change it back to 45. These are E-heads that flow 330. Only other thing I changed was increase the header primary tube length from 30 to 36.
Yesterday the DA was about +1900. I had 200lbs of ballast in the car. With the old motor it should have ran 10.05. I had a surprised when it went 9.85/135 with a best ever 60' of 1.332. Now I need a way to slow it up to run my 10.00 index. I was using weight but now need to slow it up with out adding more weight. Any ideas? I think it's time to step up and make it legal to go 9's. I wonder how fast it would go if I take the weight out and exhaust off in good air. |
9.55-9.65 is my guess. Is a throttle stop legal in your class?
I was gonna say .60.. sounds like it's time to detune the car....
Nice problem to have! Maybe take some timing out of it?
With a open tuned header system low lift ( around .200" lift) Intake and Exh air flow numbers are very important to take full advantage of the Cams overlap scaveng tuning as in making high VE numbers !
Put a restrictive 8" air filter on it and sand bags in the trunk! That latter wil also help you to keep the 60 ft times consistent.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 06-17-2019 at 06:11 AM. |
Just put a stop on the throttle so it will only open so far?
Adjust it till you get your 10 second ET. Won't affect low RPM or mid RPM 'feel', just the top end limited.
whaaaaaaaat!
Who would do such a thing ? He should be locked up and throw away the key for Adding HP. to that poor car
Shift earlier.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
That can be a good tool. If you know you got treed, you have some extra to try and run them out...
Shift earlier x2
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas |
They make a under carbspacer adjustable blades to slow car down
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
Name of company who makes restrictor is Willy’s
Could you take a little timing out to slow it up?
Maybe a real electrician can show you how to use the electric Greenlee punch kit to make the restrictor plate.
I'd dial-in a throttle limiter to back off from WOT, or drop Total ADV
No throttle stops or delay boxes allowed. I was looking at the EZ plate system (restrictor plates).They are a little pricy at $490. A lot of index racers are using them. I am going to make a few plates to try under the carb. If I can get it fairly close I can fine tune with weight.
I have been index racing since the class started. Limiting throttle open never worked for me. It doesn't slow you up as you would think. it is not linear. As soon as you get to a point little adjustments are big swings. I also never had luck with timing. Keep in mind everything you change, changes your launch thus reaction time. My car launched great with the power it was making. my lights where .012/.002/.007/.015/.022. Made it five rounds pedaling it each run. lost in the semi's my .022 light to his .014. I ran a 9.990 to his 10.000. |
I would try short shifting it. I believe you could easily get where you need to be. Probably would only have to short low gear. (I'm assuming a 3 speed, I dont know that) My car would scrub 3 tenths leaving it in drive and letting the governor shift it 550 rpms lower than optimal.(both gears) I guess you could mess with cam timing, but that's a pain, especially to go slower...
The couple guys I know that run an index class use the ET Genie. Its about the same price though as the EZ Plate system without the plates. Just turn a screw and it closes off the butterflys.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
Restrictor plates under carb work great
The EZ plate guy i'm told is out of business and will not respond to calls or emails, all the reading ive done on the subject points to the willys or et genie as suggested above, im told they are very similar but the e.t. genie has a dial to make it adjustments consistent. I wanted to run the EZ plate setup myself, but ran into the issue i described above. i am in the process of building a new motor, and would like to build it to run a little faster than the old one wide open, however, due to class flexibility, i rarely every run it wide open. i went from a 4.30 to a 3.70 gear to slow it down with the old set-up, i couldn't shift it any lower than i already was (5200). If i need to slow it down even more to run a 7.50/12.00 class, i can unhook the secondaries and kill another few tenths. Ideally i'd like to be able to open it up with the 3.70 gear and be able to dip into the 10's, but most of the time i will be looking to run 7.00/7.35/or 7.50 1/8 index and brackets. That et range gives me lots of options depending on what is paying out (s/pro,pro,sportsman,super e.t., no E, footbrake, and the various index classes and open comps)
oh and, congrats Mike.. thats badass!
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components |
