My external oil feed setup
Got my external oil feed finished and tested and I'm Verry happy.
I used a Holley fuel pressure regulator an edelbrock lo profile 3/8 male pipe to 1/8 female. I I ran into the back of the head through the lash adjuster galley plug hole. I drilled and tapped a hole next to the oil breather tube for the return. I swapped out the factory restrictor tube with a new tube to close off the factory feed Tested it tonite and was able to get an even pressure to the head
When you really do something right it's like you didn't do anything at all 1931 Pontiac 5 window coupe OHC6 powered 2015 GMC Yukon SLT |
Nice Clean Install!
Thanks for sharing.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
NICE! That is very much how I intend on doing mine next time. The only reason I drilled the head like I did was I was "told" there wasn't enough room between the head and firewall for a 90º fitting. I now know that not to be true. I plan on hard lining my next ones as well.
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
check out edelbrock for a lo profile 90 3/8 male to 1/8 female fitting
