Will a distributor with a steel gear work with both of these cams?
I have a new 455 shortblock with the Comp hydraulic flat tappet XE274 cam but I am planning on swapping it out and put in one of the SD Old Faithful hydraulic roller cams.
Will a distributor with a steel gear work with both of those cams? |
I've always used the composite distributor gear with a hyd roller cam.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
Is the roller cam an iron, or a steel core? If it's a steel core, can you get it with a pressed-on iron gear? Steel drive gear on the cam won't be compatible with a steel driven gear on the distributor.
I have tried to call SD about that old faithful cam but never can reach them. The cam is actually made by Comp. |
You will have better luck contacting SD by E-mail.
Its ok to giggle and snicker, Dont laugh and point |
Unless something has changed in the past few months, I believe all Comp Cams roller cams are steel drive gears
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
X2. They are very good with email, most the time.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
e-mail ..............Dave is Awesome
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
I do not know about the SD Perf cams, but I have had both CompCams and Bullet grind custom Pontiac HR's on cores that CAN use the stock distributor gear.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
The part number for the Old Faithful cam is 52-000-09
The -09 is designated as a "Steel Billet Roller" within the core classifications. Thus the use of a 'bronze' type gear or a composite BOP gear should be used. For the most part you will find all Comp roller cams, hyd or solid, for a Pontiac application use a steel billet core. .
Somewhat off topic....I don't understand the whole dist gear issue with roller cams.....why a bronze or composite gear needed? Steel on steel gears when lubricated seem to work a very long time........................like in transmissions, etc.
I don't get it, someone educate me. George
I had the same question last year when I went to the SD-STUM PULLER rollor cam.
With cam card in hand,I called Comp with part and grind #, they were able to tell me that came needed the bronze or composit gear. They suggested the composit gear is best. I was told by someone that the rollor cams could come either way by needing the steel or other type of disrib gear. Call Comp Cams,tell them it's an SDPERFORMANCE cam.
color me gone |
My supposition is that it relates to the crystalline structure, with distributor gears being iron and cams being steel. From first-hand experience, I can tell you what happens. Many years ago, Steve Coombes gave me a mild solid roller cam, which I was going to use in my old Firebird. My plans got delayed, but a friend (Warren Ksiez) was building a similar motor, and could use the cam immediately - with Steve's permission, the cam was given to Warren. For reasons I no longer remember, Warren tried using the cam with his stock distributor gear. Within just a few hundred miles, the distributor gear had knife-edged teeth! I still have that gear in my "show and tell" box in the garage. I can't tell you "why" it doesn't work, but I'm confident that it doesn't.
Hi there Lee, good to see you back on the Poncho board.
Lee, so ok, the cast dist gear succumbed to the steel cam gear......I can understand that, so a bronze or composite gear is supposed to last, being of a material not as hard/dense? I don't get it. I would think the steel-on-steel with forced lube would be the way to go...it works in transmissions........... Your empirical info is interesting tho. I would like to know what the deal is, I don't like mysteries. george
When I went to an old faithful grind around two years ago, Dave @ S.D. told me to use a composite gear.
Some Fear, Because if you've never been afraid- just a little. You're obviously not going as fast as you could be. |
Distributor Gears: What’s The Deal?
http://www.carcraft.com/techarticles/distributor_gears/ Comments here might be useful..... http://forums.maxperformanceinc.com/...stributor+gear COMP Cams® Quick Tech: Selecting The Correct Distributor Gear http://www.youtube.com/watch?v=pL_p-...ature=youtu.be .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 01-08-2014 at 04:30 PM. |
Can you simplify the decision and use the composite gear with ANY flavor of cam?
Same thing he told me.
The Following User Says Thank You to pggto For This Useful Post: | ||
Is it possible to swap gears on a distributor....from steel to composite? The distributor I am planning on buying has a steel gear.
Yes, need to know what distributor.
