Stocker engine, gettin close...
Stocker block, ready to go... I back cut 2nd rings, today , on lunch...took me about an hour... I cant wait to get to the point, of assembly... Building a Stocker combo, is something ive wanted to do , for almost 30 years...Crank, pistons , and rods, are ready to roll...Crank was done by Harts Machine, in Ohio... Piston skirts were coated by Swain coatings(Venolia)...It oughta run...hehe! Heads are next.
1968 Firebird 10.817/122.33 3600lbs trw 455, iron d-port heads/SD intake/q-jet, 9" tires 1.440 60ft 1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,(12.157@108.91)1.578 60' Oct 2010!! |
Dude I wish you all the luck in the world , I love stock and super stock racing also heads up but I am not a member but I spend time over at classracer.com. a lot of smart guys over there, again best of luck
Brent,
What combo are you building? What year block are you using? Calvin Hill Hill Performance 708-250-7420 |
ITs a late '67 Block... factory block for my car... 330hp ... building 330hp combo, with 16 heads(dports)...
Good luck with the project and keep us posted. Calvin Hill Hill Performance 708-250-7420 |
Thanks Calvin...im pretty excited about it... we will see what happens, in the Spring!
Good luck! That's cool your finally doing the build! I too have been wanting to do a stocker build for at least 15yrs.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.82@159.91 in Joliet May 2024 ….157.56 MPH in Gainesville in March ‘23 |
The Following User Says Thank You to S/st 54 For This Useful Post: | ||
Thanks! Ive been watching Stock , since i was in my early teens...im 44 now... Ive had this car, and engine, since i was 18...I have several 400's and heads, but decided to build the original engine, to the car... thought it would be cool , to put the engine back in , that the car rolled off the assembly line with...
Great looking 68 bird, i really like the front nose on that bird. Good luck with your build...
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ |
The Following User Says Thank You to Robert Williams For This Useful Post: | ||
Brent might give John Schloe a call for some tips. He's been doing it for a long time and his '69 bird sporting D ports goes pretty darned fast. Has his chassis well scienced out.
He gave me the lobe numbers for his RAIV cam-I sure had no V-P with it so it's on the shelf-he had a few tricks like offset dowels to locate valve exactly on the piston relief to help him.
Im working on getting the right oil rings, this week, and then i can start with assembly... Top rings, and 2 rings are fitted( i back cut 2nd ring, myself... ) ... I cant wait to get this thing together... Heads will be started on, this week... THe guy , doin my machine work, has built several record holders, Buicks and Pontiacs... Itll be up to me, as far as how much tuning, and swapping parts, how this thing ends up. Ive got a pretty good cam, to start with... May end up with a slightly bigger duration, before its all over. ...
I've still got John's copy if you want it! 274/274 @ 0.050!
Brent,you should come to the Dutch Classic and see the high tech pistons I`ve got in my motor in teardown this weekend!
The Following User Says Thank You to F/S GTO For This Useful Post: | ||
I`d be interested to know what the duration is at .200 and .250 on that cam.
if it werent so far, i would! hehe Old fashioned TRW's?
THats alot of cam! I wonder how high he buzzes that thing, to get it to run...? I have a 275/276 Solid, in my bird...i leave at 2400, and shift at 5800... but, im runnin a 455... that seems like alot of cam , for a 400/auto...It must work, though! Lots of converter, and atleast a 4.88, i bet...
