Silicone sealer for header Flange to head question?
Hey Everyone,
When sealing a header flange to a head which is better Permatex RTV red high-temperature Silicone sealant or Permatex Ultra copper high-temperature Silicone sealant? Thanks, Craig |
I use the copper one. Seems to withstand the heat longer.
I also wonder about the Permatex red RTV that is the Right-Stuff or Ultra-Red that's both have temperature rating up to 650?
i have used a few different types i am a big fan of dow 737 it is the best sealant i have used for almost any application including headers. High or low temp doesnt not seem to matter for header usage. IE copper doesnt matter in my experience.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
I've always used Ultra Gray. Several years with no issues. If nothing else, it's not as noticeable with aluminum heads and silver headers.
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U |
In my experience. Keeping the bolts from backing off is the most important thing. Many companies make kits with clips and washers. The easiest for me was safety wire. I've never had a leak if the bolts were tight.
Over the years of using copper gaskets with sealers and after trying many options of combinations of gaskets - My old machinist planed flat the flange and then I used the ultra copper without gaskets. - mufflers on the street and open headers at the track.
They are leaking now - do using mufflers and the resultant backpressure indicate a more comprehensive approach - like special gaskets, etc? Thanks, Craig |
I always use ultra copper w turbo applications these get crazy hot and have lots of back pressure and it works , regukar headers I’ve never had it fail
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
I use a 4 foot long belt sander to get mine perfect.
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
If you are running EFI or a stand alone sensor, Make sure what ever you decide to use, that it says its safe for 02 sensors.
Had better Luck just going with Remflex gaskets than multiple tries to seal with sealant a warped header flange. Do have to be gentle with them during install though.
1984 RX7 Jim Hand style 455 /200 4R Project car 67 White/Gold GTO 4 speed sold, 1968 GTO 4 speed sold, 1969 GTO auto sold, 68 Firebird 400 4 speed (455) sold, 65 GTO Night Watch Blue 4 speed sold, 64 GTO Nocturne Blue 4 speed sold, 71 GTO Gold auto sold. 1975 Formula 400 auto sold. Hopefully to be restored, H-"O" Racing 73 Trans Am SD 4 speed, Sons 70 Formula 400 auto, and wife's 1974 AMX 360 auto, 1975 Jeep Honcho 4x4, 1965 Buick Special post |
I use red or orange.
I've used ultra copper without gaskets.
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
The Following User Says Thank You to RAIV-Z For This Useful Post: | ||
I use ultra copper w wide band O2 all the time never had an issue. . Same O2 sensor in my car since 2009
Thanks Guys - I will try this:
Permatex 27038 Optimum Red High Temperature Gasket Maker, 3 oz |
The Copper is good Too!
