SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
The motor is a 1965 421 four bolt main. It was assembled by Kauffman and dynoed at 662 hp with a 950 carb. I added a vacuum pump and 1150 Dominator carb, which probably brought the HP to 700. The motor runs great and recorded a best of 10.10 in the 1/4 mile in a 3,450lb car(without the driver). The motor will only need a vacuum pump and carb. I have a DUI distributor that was on the motor that will be included.
421 block bored to 4.121 4.25 Stoke Eagle forged crank 6.800 Eagle 3D H Beam rods DSS forged pistons Comp Cams roller R9+4 275/284 duration .740/.690 lift Crower 66260 roller lifters 1.50 Scorpion roller rockers Kauffman 56cc 380cfm High Port heads Kauffman Northwind intake port matched to heads Meziere electric water pump Moroso 7 qt oil pan Performance Quotient flexplate The intake has a 4150 bolt pattern. I have an HVH 2" spacer/adapter that I will include with the motor. I will post the dyno sheet. $8,500 |
The Following User Says Thank You to 421 Bird For This Useful Post: | ||
Here is the dyno sheet.
Compression?
Compression is 14:1
Joe |
I just need a 421 assembled block. Good luck
I’ve got a 71 round port 455 with about 1000 miles on it in my convertible any interest in a trade
Sent from my iPhone using Tapatalk |
Thanks for the offer, but I am looking to sell the motor.
How many passes does the engine have on it?
I don't have all of the passes logged, but I would say there are 40-50 passes on the motor. The last time made a pass was at the Pontiac Nationals this year.
Still available
Yes, it is still available.
So the motor went 10.10 in the quarter mile without the driver? Just kidding but that sentence could be read that way. Beautiful engine and it has all of the right stuff in it.
Yes, it could read that way. Lol. I should have said 3,675 lbs with the driver.
How does the starter bolt on?
I used a Powermaster XS mini starter with no issues.
10.10 is a stick car or auto and if auto what stall, rear gear and foot brake or trans brake...
The car was an automatic with a 4,000 rpm stall converter. Rear gear was 4.11 and car was foot braked. Here is a link to the car the motor was in:
https://forums.maxperformanceinc.com...d.php?t=866641 Thanks, Joe |
The motor is sold.
Thank you, Joe |
