Old 04-16-2012, 02:31 PM
tripower's Avatar
tripower tripower is offline
Default 70-72 body mounts to frame
While loosening up (or should I say breaking) the body mount bolts on my 71, I found that I had to cut small doors to access the two far rear ones because they would not give. The square nuts seem to be loose in a small cage that is welded down to the body.
Are the nuts suppose to be welded down also of do they move within there with the cage to keep them from spinning? I also believe this is the same setup on the two mounts under the doors.
One other question..... the 71 Service Manual lists a total of four bolts on each side but I can only see three, the others seem to be just bushings resting on the frame. I found two forward (lower firewall), two under doors, and two far rear so far.
thanks
Norm J
Old 04-16-2012, 06:29 PM
mach par mach par is offline
Mine had the cages spin till they caught the frame.
1971 T-37
2004 GTO Sold
1974 Nova Sold
1967 Mustang
Old 04-16-2012, 07:38 PM
marxjunk marxjunk is offline
i pull 20+ frames a year..some time double, and how i get around it is simple, and old bodyman sowed me and works 99.9% of the time, and rarely to i use penitrating oil, because i dont want to open the floor if dont have to....
good old manual ratchet....it either breaks loose, or breaks the bolt..putting an impact on it strips out the cage and they just spin and you are screwed..just nice and slow, continous pressure and out they come
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 04-16-2012, 08:07 PM
markjenks markjenks is offline
Taking mine out, I came to the conclusion that the pads were added before the lower control arms were installed. No other good way to get to them.
(2)1940 Pontiac Deluxe Six
1953 Chevy 210
1966 Harley FLH
1972 Pontiac Lemans
Old 04-16-2012, 08:37 PM
The Boss's Avatar
The Boss The Boss is offline
The blue wrench works too.
And go racin' in the street.
Old 04-16-2012, 08:46 PM
Weird! Never knew that blue was better than chrome.
http://www.craftsman.com/shc/s/p_101...2_00934658000P
1953 Chevy 210
1966 Harley FLH
1972 Pontiac Lemans
Old 04-16-2012, 08:53 PM
The Boss's Avatar
Not that one this one!
Old 04-16-2012, 10:28 PM
GStage1's Avatar
GStage1 GStage1 is offline
Even using a manual ratchet, I broke several mounts.
Here is a brief article on the repair.
http://www.buickperformanceclub.com/...BodyMounts.htm
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 04-16-2012, 11:53 PM
i rarely ever break the cage, i could say almost never and i pull stuff out of ditches and gulleys around here...
Mark..
The Goat whisperer
Old 04-17-2012, 02:36 PM
tripower's Avatar
thanks I assume those nuts are not suppose to be welded down. It makes sense that they would design it that way so you had some room to play with when they dropped the body down at the factory.
Norm J
Old 04-17-2012, 02:37 PM
tripower's Avatar
Yes but you're not lucky enough to deal with 40 years of road salt hitting the undercarriage like we are up here
Norm J
Old 04-17-2012, 07:50 PM
Yes, yes and yes. My car is a Wisconsin car and I got out 4 out of 6 of them and was very taken care of. And that in itself is an amazing feat.
1953 Chevy 210
1966 Harley FLH
1972 Pontiac Lemans
Old 05-25-2012, 12:01 AM
YNOBIL's Avatar
YNOBIL YNOBIL is offline
When I did my '67 convert, I ended up breaking off both rear bolts. I think the factory cross threads a lot of them. They don't think anyone will ever want to unbolt them, so they don't care.
Bill
Old 05-25-2012, 07:34 AM
The Boss's Avatar
A sawsall works well too - just go straight through the rubber and the bolt. I had four I had to cut through last week - took longer to run the cords.
Old 05-25-2012, 10:30 AM
1968firebird455 1968firebird455 is offline
Send a message via AIM to 1968firebird455
I soak them in PB blaster the best I can and take them off by hand with a ratchet. Also I always tighten the bolt 1/8 turn first then back it out. I've snapped bolts that have rusted under the rubber bushings but the only cage nuts I have stripped were before I starting doing this and used the impact...
Old 05-25-2012, 11:36 AM
steve v's Avatar
steve v steve v is offline
I've drilled an 1/8" hole thru the floor pan directly above the caged nut & spray it good w/PB blaster for several days thru the hole then try to remove the bolts. 9 out of 10 times they'll come out w/o issue.
Old 05-25-2012, 05:59 PM
BAN BAN is offline
Going through this right now, i had to cut through my trunk to release the one that broke free on me. I welded the cage back on, but i left the nut loose, i also ran a bolt into the nut and checked to make sure the bolt would hang down dead straight. i wanted to make sure there was enough wiggle room for when the frame goes back under that the bolt could still go in with some play either side to account for imperfections of manufacture.
Good luck.
Sam.
