Old 04-15-2024, 09:05 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default New vacuum lines beware
Just venting here. Took out bird for a nice run yesterday and on way back swore I had miss
when at cruising rpm. Found this when o popped good tonight to double check timing.
Really it’s only a year old. This when the connection to vacuum advance on HEI.
Ironically I put old hose back on and called it a day.
Where do we get good hose from nowadays?!
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds
Old 04-15-2024, 09:20 PM
gtospieg gtospieg is offline
Unfortunately it seems to be like that with all the rubber products we get these days.
Old 04-16-2024, 02:01 AM
dataway's Avatar
dataway dataway is offline
I've noticed a lot of the color coded re-pop vacuum lines are of marginal quality. Probably a result of custom low volume product coming out of China. Best way to get good hose is to buy name brand, US made products in a spool.
Long time ago I bought a spool of 1/8, 3/16, 1/4, 5/16, 3/8" and they have lasted me for years. Not cheap though. I think the industry name is "Low Pressure Petroleum" hose.
Or order spools of Gates automotive vacuum line from lots of sources. I used to go to the auto parts store and just ask how much the entire spool of hose was.
Old 04-16-2024, 05:43 AM
Red80TA Red80TA is offline
I bought a few different brands years ago, appeared to be same stock in different packs. From day 1 the stripe rubbed off just installing it, and later dried and cracked. Replaced with local stock.
Old 04-16-2024, 05:47 AM
Gates hose in there green stripe line was the premium stuff and may still be but I can't confirm since I am still working off of 25 ft I purchased at least 18 years ago.
Old 04-16-2024, 07:52 AM
U-Pull-It hoses are the best
Old 04-16-2024, 07:55 AM
Gary H's Avatar
Gary H Gary H is offline
I recently put new heater hoses on sourced from a well-known Pontiac vendor. After getting some heat in the engine found pin hole leak in one of the brand-new hoses. Ridiculous! Also, this past week put on a brand new brake booster from the same company. Bad internal leak from the vacuum diaphragm.
