Hi
i'm curious, i assume the stock chrome pontiac valve covers do not fit on any of the kre, edelbrock,speedpro, etc manufacture heads even with thick gaskets? never seen anyone run them...
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane |
I have a set on some E heads on a new motor! Clear HS rockers fine with a thick gasket.
They fit just fine.
Edelbrock heads shown below.
thanks again! that is awesome news!!! have a great weekend everyone
Same with the KRE's.
The Following User Says Thank You to Scarebird For This Useful Post: | ||
With KRE heads from SD Performance and 1.65 Crower stainless rocker arms, I was getting a very light tap and kiss marks on my reproduction chrome covers with the thickest gasket. Ended up adding a 3/8" cover spacer and thin rubber gaskets and problem resolved.
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
The Following User Says Thank You to mrennie For This Useful Post: | ||
I wonder if your repro covers are shorter then OEM?
Does your motor run longer push rods?
As the others have stated... OE replacement covers will work. This is KRE heads, full roller valve train. Spacer and thick gasket was used.
1966 GTO Resto-Mod. 2nd owner California car, factory Air, Power Windows, Holley Sniper Quadrajet, MSD Dual-Sync, Gearstar 200-4R, Yank 2400 Stall Converter, HGM Compushift Mini, Heidt's Tall Spindle, UMI Control Arms, Hellwig sway bars, CPP Big Brakes, AR Torque Thrust M, Continental Extreme Contact DW |
I have never had to use a spacer with the aftermarket 69-70 type covers.Just use the 5/16 thick gaskets.That is with 600 plus lift and 1.65 H&S roller rockers.FWIW,Tom
The Following 3 Users Say Thank You to tom s For This Useful Post: | ||
![]() Quote:
Pushrods are 9.150". It wasn't all the rockers that touched, just one at each end of the head.
Butler sells various thickness valve cover gaskets including the 5/16 that is mentioned above and a 3/8. A 3/8 thick gasket is pretty thick and in most cases would eliminate the need for a spacer.
Tim Corcoran |
Tom where are these covers from ...Ames or...and part number if possible..
I am going to be using those covers also. I have Edelbrocks, 9.050" pushrods, PRW stainless rockers and .600" lift. I will use either thicker gaskets or spacers, what ever is needed. I want to keep a "stock" looking appearance.
