Ok, enough of this fooling around, that puppy is going in tomorrow...........had a few questions for you guys that have done this on a regular basis.
Right now i have the motor on my cradle, i plan to put the mounts & bellhousing on tomorrow. So all thats on the motor is the manifold................robbmc mini starter................oil filter housing adapter....................this is for a 66 gto, will this go in the way it sits. Read somewhere, not sure if its accurate, someone said you could get one header in with the motor............ I did this back in 2010, then i put the headers in the engine bay..........i thought i had the oil filter adapter on it...............cant remember. Thanks Rich |
Think its just easier setting headers in the bay. The oil filter adapter I think is much easier to install once headers are all bolted up, depending some times it’s harder to maneuver headers once oil filter housing is all ready bolted on. Of course the bell housing shouldn’t be a problem at all. Its like headers are laying there, start lowering motor, stop pull headers up in place then lower some more, some times stick block of wood under collectors to hold headers in place. Then drop motor completely, just got play around.
I definitely never had luck with the header is bolted to the motor and trying to put them in. The block of wood under collectors helps keeping headers up in place so their not constantly falling down. Couple of 2x4’s screwed together. You can kind of judge by eye by holding collectors up how long they have to be. Especially if it’s a one-man operation, and no second hand helping.
No way you’re gonna bolt on one header and get that engine in there. Either lay them in place before setting the engine in or put them in from underneath.
The starter and filter adapter are just more obstacles for when you’re trying to get the headers in place and bolted on, leave them off is my advice. The mini starter is lightweight so easy to install after everything is in place.
The Following 2 Users Say Thank You to b-man For This Useful Post: | ||
Yeah forget about starter, agree leave off.
The Following User Says Thank You to Gach For This Useful Post: | ||
Wow, the only two things i have on, i need to take off............lol................i can see the starter wont be too bad to put back on........... But Gach, im not sure what im doing wrong, but i couldnt get that oil filter adapter off while it was in the car to save my life.............there got to be something with my car and that adapter, i cant even see one bolt, let alone get my hand and a wrench up there.............this should be an interesting day tomorrow.
For B-man, probably a dumb question..................how much trouble putting headers on from underneath the car..............i do not have a lift................thinking just putting them in the bay which i did along time ago...............well, guess i have to take a few parts off tomorrow. Rich |
Lay the headers in the bay.
Use some house wire or coat hangers to hold them in place over a couple old towels to protect the inner fenders. Leave the filter adapter and see before you go about removing it.
![]() Quote:
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
Yeah if its that hard to get at while headers are bolted up, then leave bolted up. Yeah I’ve done coat hanger wire trick. Might be easier, or if possible stick a bolt in collector.
It!s been a Long time but both times I did mine I left the starter and oil filter adaptor off. I wrapped the headers in bubble wrap and hung them off bungee cords on both sides.
Triple Black 1971 GTO |
Long zip ties are you friend when it comes to holding your headers in the right spot while installing your engine.
So is Gorilla Tape around your header areas that lay on stuff while installing your engine. |
Doesn't anyone have a roll of mechanics wire anymore ?
I just did this with my 67. Both headers and starter off and oil adapter on. I am using Dougs Dports. Starter on before header go on.
Good luck to ya! |
Just wanted to thank you guys again for the help.............took me 3 hrs but i got it in...........i think if i had a 4bbl with that tilt deal, would have been easier, had to take off the bellhousing, just wouldnt go with that on............and the headers were a headache...................i dont even have the gaskets on yet..........lol
Should be a good trick getting those remflex gaskets on without wrecking them............will try tomorrow. I guess new motor mounts make a difference................quite a bit of room on the oil pan now.............before i might have had a 1/8 inch. Also had to take off my oil adapter off............almost fit....................didnt get too many scratches, so good to go. Rich |
Good job Rich ! God that brings back memories of my 66 GTO. Your getting there
I know plain in butt, you can always get the Mr Gasket ones from Butler. Thats the thing about dropping motors in time goes by and don’t remember what it took last time, so never know until D-day comes. Nice I didn’t know it’s a Tri Power one. Them 3 puppies.
Rich, do you have the oil filter adapter that the bottom is angled in towards the engine? A bodies need the angled one, rather than the 90 degree adapter that fits F, and B bodies. The 90 degree one will fit in an A body, but the filter will damn near rub the inner part of the frame rail.
Headers have to be in the frame when you set the engine in, bolt them on before you hook up the motor mounts preferably with the engine hanging. The higher the cylinder heads are from the chassis the easier it is to start the header bolts, and tighten them because of the added working room. |
Picture of the 90 degree adapter for all but A bodies:
![]() Picture of angled oil filter adapter for A bodies: ![]() |
The Following User Says Thank You to Sirrotica For This Useful Post: | ||
![]() Quote:
Correct I had the 90 degree adapter on when I installed my engine but could not get a filter to fit. I put the angled on and problem solved. |
Rich, if you have a good sharp pair of sheet metal sheers do this .
Bolt the headers up with all the bolts, but let it dangle off of them. Next cut your header gaskets into 3 sections , each end port and the center. Next cut slots for each bolt out of each gasket section . This will allow you to rock the header and drop in each gasket section from the top. This method also helps with relieving sheering forces induced by the motor rocking and the exh system trying to keep it from doing such. This action leads to torn header gaskets .
