Old 06-20-2020, 12:34 PM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default tri-pwr cable bracket
Does anyone know if the tri pwr cable bracket is specific for 1966 tri pwr.I'm having an issue with my linkage too. I replaced the cable but it seems like my pedal doesn't fully open my secondary carbs neither.I noticed that I have to check my bushings in my pedal also.Thanks guys for all your help.
Tim
Old 06-20-2020, 02:39 PM
Dick Boneske's Avatar
The cable is not an issue if your center carb opens fully with the gas pedal. The end carbs are easily adjusted to open when the center carb is fully open. Additionally, on the '66 only, the center carb lever extension is adjustable by bending to achieve wide open throttle. It is best if you remove the extension (one bolt) to make this adjustment.
Do not change your cable until you confirm the above. PM me if you need further detail.
Name:	'66 Tripower, Fall Colors 010.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 06-20-2020, 02:49 PM
Default tri-pwr bracket
Thanks Dick,I will do that.I have to spend some time on it to figure out where the
problem is.Working by myself so I need to get a brick to put on gas pedal,I'll get it someday.Thanks again,Tim.
Old 06-20-2020, 07:20 PM
You Should have two people do this so you know what "on the floor" is for the gas pedal. The bracket is not difficult to bend if you have a vise and an adjustable wrench.
BONESTOCK GOATS
Old 06-20-2020, 08:02 PM
gtorich gtorich is offline
Hey Dick, Rich here...……..true its not hard to bend, but no matter how much I bent it, the cable was really screwed up, bought the cable that was for a 66 tri power, ames doesn't sell the one with the 3 eye lets as far as I can see on the website.
Think I have the right bracket, the thing that was weird was the proper cable was only a hair longer than the 2 4 barrel cables I have.
I already have a nick in the plastic tube from the new cable, another $ 59 bucks down the drain. lol
I'll send you a email, maybe I can run down by you, and bring this cable with me to show you, it looks different than the one on you car.
Im thinking you run into problems doing this by hand, then when you use the actual gas pedal, yep, that's another story.
Rich
ID:	542808   Click image for larger version
ID:	542809   Click image for larger version
ID:	542812   Click image for larger version
Old 06-21-2020, 09:49 AM
I always thought 64-65 cables were close on the TRI-Power Application and the 66 cable was different and had just the one hole vs three holes. But not a 1966 Tri-Power original carbs expert by any means. All of the 1966 intakes I ran carbs on had adapter plates and Holley carbs and filters.
Old 06-21-2020, 10:31 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Originally Posted by Tim66 View Post
Does anyone know if the tri pwr cable bracket is specific for 1966 tri-power
Tim66,
Yes, the 1966 throttle cable bracket is specific for the Tri-Power.
The factory part number on the bracket and in the MPC is #9783286.
Sometimes the number 4 was stamped first at the end and then the number 6 was stamped on top of it as shown below.
Chris.
ID:	542848   Click image for larger version
ID:	542849   Click image for larger version
ID:	542850   Click image for larger version
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 06-21-2020, 10:36 AM
60sstuff's Avatar
OEM Tri-Power throttle cables.
1964 - 3 holes at the end.
1965 - 1 hole at the end.
1966 - 1 hole at the end.
Chris.
ID:	542852   Click image for larger version
ID:	542853   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 06-21-2020, 12:06 PM
Thanks guys your the best,I know we'll figure it out.
Tim
Old 06-21-2020, 12:10 PM
THANKS! 60SSTUFF.
Apparently I need to pay more attention on the 1965 Tri-Power Intakes, but have never owned a 65 Tri-Power intake set-up. Learning every day.
Old 06-21-2020, 06:24 PM
Chris is correct. We got Rich's '66 squared away. He installed the cable from Ames, but did not get near full throttle. We bent the "adjustable" arm on the center carb bracket and attained full throttle.
BONESTOCK GOATS
The Following User Says Thank You to Dick Boneske For This Useful Post:
Old 06-21-2020, 07:18 PM
Thanks again Dick, seems you bend stuff way better than I do. lol
This new correct cable seems to be ok, looks different than what is posted on post 7 from 60" stuff...…….seems I might have
Old 06-21-2020, 07:23 PM
Not sure what happened on that post...……….my bracket does not have the #"s on it, but its the same. Its hard to believe but seems like these cables are about a 1/8 or so in difference...……..the cable im replacing looks more like the one 60"s stuff has in post # 7.
Everything is working good now, so im leaving it alone. lol
Thanks for everyones help on this deal.
Rich
Old 12-19-2023, 01:27 PM
SD421's Avatar
SD421 SD421 is offline
Hi Dick,
I’m trying to figure out exactly what you mean by “bending” the center carb to adjust it.
Could you post another pic pointing to what it is that you are referring to?
Thanks,
Don
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 12-19-2023, 04:26 PM
Look at the center carb bracket with the curved bend and sturd with cotter pin. That portion of the bracket is designed to be bent to confirm to your throttle cable to allow wide open throttle and idle.
DM me if you need more detail.
Name:	'66 Tripower GTO Power Brake Line Automatic 002.jpg
BONESTOCK GOATS
