Butler oil pump shaft
Are these the tabs you guys are talking about on the shaft.............thought they would be bigger...........hope i got the right one.
This is their hardened shaft.............getting a new oil pump also from precision oil pumps, they have a billet shaft........would this be better than what i have. Rich |
I guess the Billet is a bit stronger, but not a deal breaker if your only running a 60 psi pump I would say.
I do stuff for reasons. |
Probably getting a little off track here, but anyone have any pics of a strap securing the oil pick up screen to the pump. Rich |
These guys have nice ones too. I'm using the IA2 one. http://www.nitemareperformance.com/prices2.html
Rich, so which pump are you planing on running?
Your asking about the retention strap, so is it that you have a pick up tube without a strap?
25 Steve......i have the melling stock replacement pick up # 54 DS........dont have it yet, dont think there is a strap on it from the pic.
Are there other pick ups i could use with the strap...........let me know, i could pick them up. I have both pumps a 60 and a 80lb.........rare that i shift higher than 57-5800 rpm, unless im really not paying attention, think i have the rev limiter at 5900.......did a search on the forum about the differences between the two...........seems its either the 60 camp or the 80 camp..........no switching their minds.....lol |
My 2 cents would be that pump wise unless your road racing a 3.250” main crank that for more then 50% of its run time would be above 4500 to 5000 rpm, I see no need for a 80 psi pump in a street strip motor.
It’s easy to make a pick up tube rap around support bracket out of narrow angle iron or thick enough sheet steel that the bolts to the pump . All you need is a longer bolt If your running a stock type round pick up this strap only holds the pick up into the pump since the pump has a cast in nose that locates the proper pick up height off the pans bottom plus keeps the pick up from spinning up towards the crank should it start to work loose if you ran the pick up with no strap.
no need or benefit using a 80lb pump on a street car that barely sees 6000 rpm.
you can add a hardened washer to shim the spring a bit for a few added psi along with a bigger check ball. did that on my 400/467 stroker, using 10/30 oil i get 70-80 psi at "cold" 75-80f start up, then a solid 25 hot idle. more is not better in this type of situation. |
What if a guy is spinning to 7000 rpm? I run a 60 psi pump to 7000 rpm. It puts out 65 psi at that rpm. Thoughts? Thanks No issues so far. 20w-50 Amsoil.
will leave that to the experts to answer, but if its sees above 6000 on a regular basis then a higher psi pump may be a benefit. however if you have adequate psi (~10psi/1000rpm) with the pump/oil you are using now then its probably OK as is or consider shimming the spring for a little extra psi.
The Following User Says Thank You to 78w72 For This Useful Post: | ||
Found this little graph online. Show pressure to journal size.
The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
60psi is fine, I ran to 8000 with 65psi and 9000 with 60psi. Worry more about flow than psi.
Thanks. My IA2 is only 3 inch main bearings with a 4.25 stroke. I've been reading alot on oil flow with oil filters lately and micron ratings. Interesting stuff.
Hmmm, do tell............. |
The Following User Says Thank You to Sirrotica For This Useful Post: | ||
Maybe I have been the luckiest Pontiac guy alive but I have NEVER broken an oil pump drive in any Pontiac engine that was running correctly. I have seen a fair amount of wear on the tangs after 150, 200K miles. I have seen the tangs break when something else got into the oil pump and locked the gears or got jammed between the gear and the housing. But I have never seen one break just from metal fatigue. I have seen many Ford oil pump drives break or twist up like a barber pole, but they use a tiny allen wrench looking drive that is a mile long. I think it's only 1/4". On a Pontiac, just make sure the drive rod has a little up and down wiggle room with the distributor installed and don't worry about it. Think about it. A regular 14 volt cordless drill has no trouble turning a Pontiac oil pump for priming the engine. It will even do an 80 lb. pump just fine. How much HP can it possibly take to run the pump. Maybe 2 maximum. With the 80 lb. pump, the factory did supply a hardened drive shaft.
engine masters back to back tested every oil pump available for a 440 Mopar because its an external pump lending itself to quick change high pressures low pressures high low volumes and even a gearotor milodon pump
other than 1 or so HP variations from run to run attributed to engine temp and oil temp and basic dyno variations they basically came up with myth busted on the great loss of power using a high pressure pump Last edited by Formulas; 10-22-2022 at 06:06 PM. |
The Following User Says Thank You to Formulas For This Useful Post: | ||
The Following User Says Thank You to mgarblik For This Useful Post: | ||
It takes considerable knowledge just to realize the extent of your own ignorance. Dr. Thomas Sowell |
From Butler Performance: https://www.pontiacv8.com/articles/2018/3/26/oilpump
Butler says that since an engine with smaller-diameter main journals (3-inch) and shorter-stroke crankshafts (4.21-inch or less) is generally less stressful on the bearings, a 60-psi pump may provide adequate lubrication in a modified engine, but an 80-psi pump is a better choice. He says any performance engine with 3.25-inch-diameter main journals and/or a stroker length greater than 4.21 inches should use an 80-psi pump. “The greater oil pressure associated with the 80-psi pump improves the strength of the oil film, and better protects the bearings in large journal and/or long-stroke applications,” he adds. Common hobbyist concerns when using an 80-psi oil pump in a street engine include excessive parasitic loss, bearing wash, and premature distributor and/or cam gear wear. “We’ve never seen a noticeable performance loss from the added load,” says Butler. “Racers will sometimes run a 60-psi pump to reduce parasitic drag and free up a few horsepower. While that’s acceptable in a dedicated race engine that’s frequently torn down, it’s certainly not something we recommend for all engines.”
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears 66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Thread Tools | |
Display Modes | |
