Speedometer
Speedometer is not reading accurate speed,reads slower than actual speed.
Is this a cable problem or speedo gear problem 1967 Sport Coupe w/Criuse Control Thanks in advance.
1967 GTO Sport Coupe 49,xxx orig.miles Champagne/Parchment 30 Original Owner Ordered PHS Documented Factory Options Second Owner |
Your signature states 48k original miles, any changes to the drive train or tire size? Did it just start out of the blue?
The More People I Meet, The More I Love My Dogs! |
Just started out of the blue,still retains 14" wheel size..also still retains original rear gear.
Besides the 14" rim, has the tire size changed from original size?
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
Over time the magnetism slowly diminishes, when the speedometer was made brand new GM over-magnetized them on purpose. And for about the first 6 months or a year they will read a bit more on your dash dial than actual road speed. After about a year the "set" of the iron settles into a very stable mode and it will say like that for at least the next 25-30 years. After 30 years or so, in many cases the magnetism inside of the speedometer weakens resulting in readings on your dash dial less than actual road speed. (This is assuming that all of the other parts: the cable, gearing, tire size, etc, are correct for the car.)
Every single one of these old speedometers should be serviced at least once every 30 years. The old lubrication dries out and if you run one until it "locks up" the delicate inner workings of the speedometer are destroyed. At least once every 30 years you should have a complete tear down; through cleaning checking all the gears, the bronze bushing, the main input shaft as well as the odometer copper shaft. Then re-lubrication, re-mag and calibration. If one locks up on you while you are driving the parts inside which will break are no longer available as service or repair parts. In order to fix one of those you need to find another complete good used undamaged speedometer to get parts.
Peter Serio Owner, Precision Pontiac |
Thread Tools | |
Display Modes | |
