The first question needing to be asked in terms of what rear gear is at what rpm does the motor start to pull hard and then at what rpm does it feel like it's making peak Torque in whatever gear 1 to 1 is, then you want to gear for a normal cruse rpm of about 500 less.
Peak Torque rpm will usually coenside with the point in rpm where the fast gain in seen in rpm levels off.
