06-18-2015, 12:34 AM
Diego,
Here are some other posts that I dug up from some old threads that allude to the same document
Originally Posted by gtoric
The entire 33 body style line was refered to as the Tempest for the entire model year. The Pontiac Accessorizer effective September 18, 1969 lists:
Tempest Coupe (3327)
Tempest 4-Door Sedan (3369)
The Pontiac Accessorizer effective February 24, 1970 lists:
Tempest T-37 Hardtop Coupe (3337)
There is not a listing for the GT Sport Package (GT-37) in this later edition of the Accessorizer, thus adding further creedence to the May intro date.
There were no post (3327) T-37s built in 1970, no such animal, but the GT Sport Package was available on both 2-door body styles of the Tempest. As JLP states, a V-8 was a manditory option.
Originally Posted by Judge Man
I have a book called Standard Catalog Of Pontiac 1926-1995.It mentions that the Tempest is a 2dr HT and in Februrary 1970 the T-37 2dr ht coupe was introduced.It says for both cars that the body style number is 23337.It does'nt mention that the T-37 or the Tempest was strickly a Post or HT.
Originally Posted by 'ol Pinion head
The T-37 name indeed was introduced in the Spring of 1970. There are some notes of the T-37 being introduced in February. I've yet to physically examine one built that early & I've been writing down 70 VINs & body build numbers for many years. Both the potmetal Tempest plate (emblem) #479180 along with the black & white T-37 decal 481938 on the fender, is how the cars were badged. When the '70 1/2 GT-37's rolled out in May, they carried the GT-37 decal 483376 below the Tempest "emblem".
In August of '70, when the first '71 T-37's rolled off the lines, the potmetal Tempest fender ID was no longer used, replaced by the potmetal plate PONTIAC 483926. Also a new for '71 potmetal fender plates T-37 483946, & GT-37 483947 were mounted below the PONTIAC. The 483947 GT-37 emblem was deleted when the '71 1/2 GT-37's were built (03B-03C & later body builds)
For '72, the 233 series line was gone. The 2D27-2D37 LeMans line was now the base line. On the fenders the raised potmetal PONTIAC plate were no more. Instead, there was a more flush mount brushed finish LeMans plate 487743 that was used on the front fenders. I've parted quite a few '72 LeMans GT's including an early built (Sept) quezal gold 350-3spd car & all included this design of emblem, er plate. Mark, I bet if you were to pull the front fenders and look at the dates stamped up by the marker light flange, it will confirm the '72 post car is indeed a '72 LeMans post, & the fenders were swapped out or new emblem holes were drilled, def not a T-37. Fairly common for such happenings over the years, I bought a fairly solid '71 23337 partscar about 12 years ago that '72 endura fenders on it.
Of note, the lightest '72 LeMans were the 2 door post cars. Vinyl flooring & non hidden wipers were standard as was the lighter standard interior panels, similar type standard equipment as on a '70 Tempest, Tempest T-37, & '71 T-37. When one ordered a '72 Lemans hardtop for '72 it came standard with carpet & hidden wipers.
