View Single Post
  #61
Old 12-22-2020, 08:32 PM
iceman411's Avatar
iceman411 iceman411 is offline
So... this past Saturday I swapped the trans pan with a new one that came in black... I prefer anything over black paint wise, so left over Pontiac blue it is... joined the engine and trans together and a baby 3000 converter and into the frame rails it went... the only thing I had to do was pull the rear transmission mount and even with the starter, it went right in.... Even with the Moroso 7qt oil pan and all... no paint chips either.... the headers still need to be recoated so I’m holding off on those... I also need a trans cable bracket that mounts to the pan for a TH-400 if anyone has one laying around... Inline Tube has them if not...
You will see the build theme start to come together on this one as it progresses...
ID:	556689   Click image for larger version
'71 LeMans Sport convertible under going a frame off restoration
