View Single Post
Old 01-27-2021, 07:56 PM
mrennie's Avatar
mrennie mrennie is offline
I'd like HOPE that it at least is correct for ONE year out of the five that they sell it to fit
I've only ever seen them advertised at fitting 68-70, with modifications required for 68 (I thought 68-69, but 6T9GTO clarified that 69's use shroud to retain the rad so must be only 68 that needs the tabs cut off.)
The bottom and side rails are probably fine for 71/72, but top is totally different.
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
