Originally Posted by yellow1098
Thanks guys I will check out tin Indian as chuckles mentioned……are there any other places or ways to get a larger diameter setup?
You will really like there product. You don't want any larger pulley than they supply for the crank. They also fit really nice inside the crank pulley. You can shim your Vacuum pump bracket and choose different collars on the mandrel..
